URLNamedLocation 属性 (ActiveX)
指定 Hyperlink 对象的命名位置。 支持的平台:仅限 Windows 属性值只读:不 类型:字符串 一个字符串,表示对象的命名位置。Hyperlink 言论此特性指定给定位置,例如AutoCAD中的命名视图或文字处理程序中的书签。如果在 AutoCAD 图形中指定要跳转到的命名视图,则在打开超链接时,AutoCAD 将恢复该视图。在模型空间中创建的视图将在“模型”选项卡中恢复。在图纸空间中创建的视图将在上一个活动版面选项卡中恢复。 例子VBA: Sub Example_URLNamedLocation()
' This example creates a Circle object in model space and
' adds a new Hyperlink to its Hyperlink collection
Dim Hyperlinks As AcadHyperlinks
Dim Hyperlink As AcadHyperlink
Dim circleObj As AcadCircle
Dim radius As Double
Dim HLList As String
' Define the Circle object
centerPoint(0) = 0: centerPoint(1) = 0: centerPoint(2) = 0
radius = 5#
' Create the Circle object in model space
Set circleObj = ThisDrawing.ModelSpace.AddCircle(centerPoint, radius)
' Get reference to the Circle's Hyperlinks collection
Set Hyperlinks = circleObj.Hyperlinks
' Add a new Hyperlink complete with all properties
Set Hyperlink = Hyperlinks.Add("AutoDesk")
Hyperlink.URL = "www.autodesk.com"
Hyperlink.URLDescription = "Autodesk Main Site"
Hyperlink.URLNamedLocation = "MY_LOCATION"
' Read and display a list of existing Hyperlinks and
' their properties for this object
For Each Hyperlink In Hyperlinks
HLList = HLList & "____________________________________" & vbCrLf ' Separator
HLList = HLList & "URL: " & Hyperlink.URL & vbCrLf
HLList = HLList & "URL Description: " & Hyperlink.URLDescription & vbCrLf
HLList = HLList & "URL Named Location: " & Hyperlink.URLNamedLocation & vbCrLf
Next
MsgBox "The circle has " & Hyperlinks.count & " Hyperlink: " & vbCrLf & HLList
可视化 LISP: (vl-load-com)
(defun c:Example_URLNamedLocation()
;; This example creates a Circle object in model space and
;; adds a new Hyperlink to its Hyperlink collection
;; Define the Circle object
(setq centerPoint (vlax-3d-point 0 0 0)
radius 5)
;; Create the Circle object in model space
(setq circleObj (vla-AddCircle modelSpace centerPoint radius))
(vla-ZoomAll acadObj)
;; Get reference to the Circle's Hyperlinks collection
(setq Hyperlinks (vla-get-Hyperlinks circleObj))
;; Add a new Hyperlink complete with all properties
(setq Hyperlink (vla-Add Hyperlinks "Autodesk"))
(vla-put-URL Hyperlink "www.autodesk.com")
(vla-put-URLDescription Hyperlink "Autodesk Main Site")
(vla-put-URLNamedLocation Hyperlink "MY_LOCATION")
;; Read and display a list of existing Hyperlinks and
;; their properties for this object
(setq HLList "")
(vlax-for Hyperlink Hyperlinks
(setq HLList (strcat HLList "____________________________________" ;; Separator
"\nURL: " (vla-get-URL Hyperlink)
"\nURL Description: " (vla-get-URLDescription Hyperlink)
"\nURL Named Location: " (vla-get-URLNamedLocation Hyperlink)))
(alert (strcat "The circle has " (itoa (vla-get-Count Hyperlinks)) " Hyperlink: \n" HLList))
GMT+8, 2026-10-27 01:19
