UnitsFormat 属性 (ActiveX)
2024-5-18 16:55| 发布者: admin| 查看: 779| 评论: 0|原作者: admin|来自: AutoCAD
指定除角度之外的所有尺寸的单位格式。
object.UnitsFormat
类型:DimAligned、DimArcLength、DimDiametric、DimOrdinate、DimRadial、DimRadialLarge、DimRotated
此属性应用于的对象。
只读:不
类型:枚举acDimLUnits
  • acDimLScientific
  • acDimLDecimal
  • acDimLEngineering
  • acDimLArchitectural
  • acDimLFractional
  • acDimLWindowsDesktop
此属性的初始值为 。acDimLDecimal
如果此属性设置为 ,则 和 属性指定的格式将用于设置十进制值的格式。acDimLDecimalDecimalSeparatorPrimaryUnitsPrecision
若要创建堆叠体系结构或分数单位格式,请使用该属性。FractionFormat
注意:此属性将覆盖给定维度的 DIMLUNIT 系统变量的值。
Sub Example_UnitsFormat()
   ' uses UnitsFormat to cycle through some common unit formats
   ' for the dimension
    Dim dimObj As AcadDimAligned
    ' Define the dimension
    point1(0) = 0: point1(1) = 5: point1(2) = 0
    point2(0) = 5.12345678: point2(1) = 5: point2(2) = 0
    ' Cycle through common unit formats
    dimObj.UnitsFormat = acDimLScientific     ' Change format to Scientific
    MsgBox "The dimension units are now set to Scientific"
    dimObj.UnitsFormat = acDimLDecimal        ' Change format to Decimal
    MsgBox "The dimension units are now set to Decimal"
    dimObj.UnitsFormat = acDimLArchitectural  ' Change format to Architectural
    MsgBox "The dimension units are now set to Architectural"
    dimObj.UnitsFormat = acDimLWindowsDesktop ' Change format to WindowsDesktop
    MsgBox "The dimension units are now set to Windows Desktop"
(defun c:Example_UnitsFormat()
    ;; uses UnitsFormat to cycle through some common unit formats
    ;; for the dimension
    ;; Define the dimension
    (setq point1 (vlax-3d-point 0 5 0)
          point2 (vlax-3d-point 5.12345678 5 0)
    (vla-ZoomAll acadObj)
    ;; Cycle through common unit formats
    (vla-put-UnitsFormat dimObj acDimLScientific)     ;; Change format to Scientific
    (alert "The dimension units are now set to Scientific")
    (vla-put-UnitsFormat dimObj acDimLDecimal)        ;; Change format to Decimal
    (alert "The dimension units are now set to Decimal")
    (vla-put-UnitsFormat dimObj acDimLArchitectural)  ;; Change format to Architectural
    (alert "The dimension units are now set to Architectural")
    (vla-put-UnitsFormat dimObj acDimLWindowsDesktop) ;; Change format to WindowsDesktop
    (alert "The dimension units are now set to Windows Desktop")
GMT+8, 2026-10-27 08:58
