TwistAngle 属性 (ActiveX)
指定视口的扭转角度。 支持的平台:仅限 Windows 属性值只读:不 类型:双 以弧度为单位的扭转角。 言论此方法会扭曲或倾斜视线周围的视图。AutoCAD 逆时针测量扭转角度,向右 0 度。 例子VBA: Sub Example_TwistAngle()
' This example creates a new paper space viewport.
' It then displays the twist angle of the viewport.
Dim pviewportObj As AcadPViewport
Dim center(0 To 2) As Double
Dim width As Double
Dim height As Double
' Define the pviewport
center(0) = 3: center(1) = 3: center(2) = 0
width = 40
height = 40
' Change from model space to paper space
ThisDrawing.ActiveSpace = acPaperSpace
' Create the pviewport
Set pviewportObj = ThisDrawing.PaperSpace.AddPViewport(center, width, height)
pviewportObj.Display True
ThisDrawing.MSpace = True
ThisDrawing.ActivePViewport = pviewportObj
' Find the twist angle for the viewport
Dim twistAngle As Double
twistAngle = pviewportObj.TwistAngle
MsgBox "The twist angle of the paper space viewport is " & pviewportObj.twistAngle, , "TwistAngle Example"
可视化 LISP: (vl-load-com)
(defun c:Example_TwistAngle()
;; This example creates a new paper space viewport.
;; It then displays the twist angle of the viewport.
;; Define the pviewport
(setq center (vlax-3d-point 3 3 0)
width 40
height 40)
;; Change from model space to paper space
(vla-put-ActiveSpace doc acPaperSpace)
;; Create the pviewport
(setq paperSpace (vla-get-PaperSpace doc))
(setq pviewportObj (vla-AddPViewport paperSpace center width height))
(vla-Display pviewportObj :vlax-true)
(vla-put-MSpace doc :vlax-true)
(vla-put-ActivePViewport doc pviewportObj)
;; Find the twist angle for the viewport
(setq twistAngle (vla-get-TwistAngle pviewportObj))
(alert (strcat "The twist angle of the paper space viewport is " (rtos twistAngle 2)))
GMT+8, 2026-10-27 05:43
