TrueColorImages 属性 (ActiveX)
确定光栅和渲染图像是以真彩色还是托盘化颜色显示。 支持的平台:仅限 Windows 属性值只读:不 类型:布尔
言论此属性的初始值为 False。 例子VBA: Sub Example_TrueColorImages()
' This example reads and modifies the preference value which determines
' if raster and render images are displayed at True Color or palletized color.
' When finished, this example resets the preference value back to
' it's original value.
' This example uses the "2d Projected Polylines.jpg" found in the sample
' directory. If you do not have this image, or it is located
' in a different directory, insert a valid path and file name
' for the imageName variable below.
Dim ACADPref As AcadPreferencesDisplay
Dim scalefactor As Double, rotationAngle As Double
Dim imageName As String
Dim rasterObj As AcadRasterImage
imageName = "c:\AutoCAD\sample\2d Projected Polylines.jpg"
' Define Raster object
insertionPoint(0) = 5: insertionPoint(1) = 5: insertionPoint(2) = 0
scalefactor = 5#: rotationAngle = 0
On Error GoTo ERRORTRAP
' Loads a raster image into model space
Set rasterObj = ThisDrawing.ModelSpace.AddRaster(imageName, insertionPoint, scalefactor, rotationAngle)
' Get the display preferences object
Set ACADPref = ThisDrawing.Application.Preferences.Display
originalValue = ACADPref.TrueColorImages
MsgBox "The TrueColorImages preference is set to: " & originalValue
' Modify the TrueColorImages preference by toggling the value
ACADPref.TrueColorImages = Not (originalValue)
newValue = ACADPref.TrueColorImages
MsgBox "The TrueColorImages preference has been set to: " & newValue
' Reset the preference back to it's original value
' this preference in effect
ACADPref.TrueColorImages = originalValue
MsgBox "The TrueColorImages preference was reset back to: " & originalValue
Exit Sub
' If you got an error (most likely a problem with the file path),
' then display an error message
ERRORTRAP:
If Err.Description <> "" Then
MsgBox Err.Description
End If
可视化 LISP: (vl-load-com)
(defun c:Example_TrueColorImages()
;; This example reads and modifies the preference value which determines
;; if raster and render images are displayed at True Color or palletized color.
;; When finished, this example resets the preference value back to
;; it's original value.
;; This example uses the "2d Projected Polylines.jpg" found in the sample
;; directory. If you do not have this image, or it is located
;; in a different directory, insert a valid path and file name
;; for the imageName variable below.
;; Define Raster object
(setq insertionPoint (vlax-3d-point 5 5 0)
imageName ".\\Sample\\VBA\\2d Projected Polylines.jpg"
scalefactor 5
rotationAngle 0)
(if (/= (findfile imageName) nil)
(progn
;; Creates a raster image in model space
(setq raster (vla-AddRaster modelSpace (findfile imageName) insertionPoint scalefactor rotationAngle))
(vla-ZoomExtents acadObj)
;; Get the display preferences object
(setq ACADPref (vla-get-Display (vla-get-Preferences acadObj)))
(setq originalValue (vla-get-TrueColorImages ACADPref))
(alert (strcat "The TrueColorImages preference is set to: " (if (= originalValue :vlax-true) "True" "False")))
;; Modify the TrueColorImages preference by toggling the value
(vla-put-TrueColorImages ACADPref (if (= originalValue :vlax-true) :vlax-false :vlax-true))
(alert (strcat "The TrueColorImages preference has been set to: " (if (= (vla-get-TrueColorImages ACADPref) :vlax-true) "True" "False")))
;; Reset the preference back to it's original value
;; this preference in effect
(vla-put-TrueColorImages ACADPref originalValue)
(alert (strcat "The TrueColorImages preference was reset back to: " (if (= (vla-get-TrueColorImages ACADPref) :vlax-true) "True" "False")))
(alert (strcat imageName " could not be found."))
GMT+8, 2026-10-27 04:52
