TrueColor 属性 (ActiveX)
2024-5-18 16:55| 发布者: admin| 查看: 689| 评论: 0|原作者: admin|来自: AutoCAD
指定对象的真实颜色。
object.TrueColor
类型:所有图形对象、AttributeReference、尺寸、组、图层
此属性应用于的对象。
只读:不
类型:AcCmColor
对象的 True Color 对象。
此属性用于更改对象的颜色。颜色由对象标识。此对象可以保存 RGB 值、ACI 编号(从 1 到 255 的整数)或命名颜色。使用 RGB 值,您可以从数百万种颜色中进行选择。AcCmColor
Sub Example_TrueColor()
    ' This example draws a line and returns the RGB values
    Dim color As AcadAcCmColor
    Set color = AcadApplication.GetInterfaceObject("AutoCAD.AcCmColor." & Left(CStr(AcadApplication.Version), 2))
    color.SetRGB 80, 100, 244
    Dim line As AcadLine
    startPoint(0) = 1#: startPoint(1) = 1#: startPoint(2) = 0#
    endPoint(0) = 5#: endPoint(1) = 5#: endPoint(2) = 0#
    Set line = ThisDrawing.ModelSpace.AddLine(startPoint, endPoint)
    ZoomAll
    line.TrueColor = color
    Dim retcolor As AcadAcCmColor
    Set retcolor = line.TrueColor
    MsgBox "Red = " & retcolor.Red & vbLf & _
           "Green = " & retcolor.Green & vbLf & _
           "Blue = " & retcolor.Blue
(defun c:Example_TrueColor()
    ;; This example draws a line and returns the RGB values
    (setq color (vlax-create-object (strcat "AutoCAD.AcCmColor." (substr (getvar "ACADVER") 1 2))))
    (vla-SetRGB color 80 100 244)
    (setq startPoint (vlax-3d-point 1 1 0)
          endPoint (vlax-3d-point 5 5 0))
    (vla-ZoomAll acadObj)
    (vla-put-TrueColor lineObj color)
    (setq retcolor (vla-get-TrueColor lineObj))
    (alert (strcat "Red = " (itoa (vla-get-Red retcolor))
                   "\nGreen = " (itoa (vla-get-Green retcolor))
                   "\nBlue = " (itoa (vla-get-Blue retcolor))))
GMT+8, 2026-10-27 05:42
