ToolPalettePath 属性 (ActiveX)
2024-5-18 16:55| 发布者: admin| 查看: 691| 评论: 0|原作者: admin|来自: AutoCAD
设置工具选项板路径。
object.ToolPalettePath
类型:PreferencesFiles
此属性应用于的对象。
只读:不
类型:字符串
工具选项板路径。
Sub Example_ToolPalettePath()
    'This example changes the tool palette path
    'and then sets it to its original string
    Dim pref As AutoCAD.AcadPreferencesFiles
    Set pref = AcadApplication.Preferences.Files
    Dim defToolPalettePath As String
    Dim changedToolPalettePath As String
    defToolPalettePath = pref.ToolPalettePath
    MsgBox "The current tool palette path is " & defToolPalettePath
    pref.ToolPalettePath = "c:\winnt;c:\temp"
    changedToolPalettePath = pref.ToolPalettePath
    MsgBox "The changed tool palette path is " & changedToolPalettePath
    pref.ToolPalettePath = defToolPalettePath
(defun c:Example_ToolPalettePath()
    ;; This example changes the tool palette path
    ;; and then sets it to its original string
    (setq pref (vla-get-Files (vla-get-Preferences acadObj)))
    (setq defToolPalettePath (vla-get-ToolPalettePath pref))
    (alert (strcat "The current tool palette path is " defToolPalettePath))
    (vla-put-ToolPalettePath pref "c:\\winnt;c:\\temp")
    (alert (strcat "The changed tool palette path is " (vla-get-ToolPalettePath pref)))
    (vla-put-ToolPalettePath pref defToolPalettePath)
GMT+8, 2026-10-27 05:22
