Toolbars 属性 (ActiveX)
获取 Toolbars 集合。 支持的平台:仅限 Windows 言论没有其他评论。 例子VBA: Sub Example_Toolbars()
' This example finds the names of the all toolbars in the first menu group.
Dim toolbarNames As String
Dim toolbarCollection As AcadToolbars
Dim toolbar As AcadToolbar
Set toolbarCollection = ThisDrawing.Application.MenuGroups.Item(0).Toolbars
toolbarNames = ""
For Each toolbar In toolbarCollection
toolbarNames = toolbarNames & toolbar.name & vbCrLf
Next toolbar
MsgBox toolbarNames
可视化 LISP: (vl-load-com)
(defun c:Example_Toolbars()
;; This example finds the names of the all toolbars in the first menu group.
(setq toolbarCollection (vla-get-Toolbars (vla-Item (vla-get-MenuGroups acadObj) 0))
toolbarNames "")
(vlax-for toolbar toolbarCollection
(setq toolbarNames (strcat toolbarNames (vla-get-Name toolbar) "\n"))
(alert toolbarNames)
GMT+8, 2026-10-28 10:49
