ToleranceSuppressZeroInches 属性 (ActiveX)
2024-5-18 16:55| 发布者: admin| 查看: 677| 评论: 0|原作者: admin|来自: AutoCAD
指定在公差值中隐含零英寸测量值。
object.ToleranceSuppressZeroInches
类型:DimAligned、DimArcLength、DimDiametric、DimOrdinate、DimRadial、DimRadialLarge、DimRotated
此属性应用于的对象。
只读:不
类型:布尔
  • True:禁止显示零英寸测量值。
  • False:请勿禁止显示零英寸测量值。
此属性的初始值为 。False
注意:此属性将覆盖给定维度的 DIMTZIN 系统变量的值。
Sub Example_ToleranceSuppressZeroInches()
    ' uses ToleranceSuppressZeroInches to toggle the display of zeros inches
    ' in the dimension tolerance display
    Dim dimObj As AcadDimAligned
    ' Define the dimension
    point2(0) = 6.01: point2(1) = 5: point2(2) = 0
    location(0) = 5: location(1) = 8: location(2) = 0
    dimObj.UnitsFormat = acDimLArchitectural
    ' Enable and setup tolerance display
    dimObj.ToleranceDisplay = acTolLimits
    dimObj.ToleranceLowerLimit = -95#: dimObj.ToleranceUpperLimit = 95#
    ZoomAll
Toggle:
    Select Case MsgBox("Press OK to toggle the display of zero inches in the dimension tolerance", vbOKCancel)
        Case vbOK
            ' Toggle the display of zero inches for the dimension tolerance value
            dimObj.ToleranceSuppressZeroInches = Not (dimObj.ToleranceSuppressZeroInches)
        Case vbCancel
            Exit Sub
    End Select
    GoTo Toggle
(defun c:Example_ToleranceSuppressZeroInches()
    ;; uses ToleranceSuppressZeroInches to toggle the display of zeros inches
    ;; in the dimension tolerance display
    ;; Define the dimension
          point2 (vlax-3d-point 6.01 5 0)
          location (vlax-3d-point 5 8 0))
    (vla-put-UnitsFormat dimObj acDimLArchitectural)
    ;; Enable and setup tolerance display
    (vla-put-ToleranceDisplay dimObj acTolLimits)
    (vla-put-ToleranceLowerLimit dimObj -95)
    (vla-put-ToleranceUpperLimit dimObj 95)
    (vla-ZoomAll acadObj)
    ;; Toggle the display of zero inches for the dimension tolerance value
    (vla-put-ToleranceSuppressZeroInches dimObj (if (= (vla-get-ToleranceSuppressZeroInches dimObj) :vlax-true) :vlax-false :vlax-true))
    (alert "Suppression of zero inches toggled.")
    ;; Toggle the display of zero inches for the dimension tolerance value back to previous state
    (alert "Suppression of zero inches toggled back.")
GMT+8, 2026-10-28 01:45
