ToleranceSuppressZeroFeet 属性 (ActiveX)
2024-5-18 16:55| 发布者: admin| 查看: 586| 评论: 0|原作者: admin|来自: AutoCAD
指定在公差值中隐含零英尺测量值。
object.ToleranceSuppressZeroFeet
类型:DimAligned、DimArcLength、DimDiametric、DimOrdinate、DimRadial、DimRadialLarge、DimRotated
此属性应用于的对象。
只读:不
类型:布尔
  • True:禁止显示零英尺测量值。
  • False:不要禁止显示零英尺测量值。
此属性的初始值为 。False
注意:此属性将覆盖给定维度的 DIMTZIN 系统变量的值。
Sub Example_ToleranceSuppressZeroFeet()
    ' uses ToleranceSuppressZeroFeet to toggle the display of zeros feet
    ' in the dimension tolerance display
    Dim dimObj As AcadDimAligned
    ' Define the dimension
    point2(0) = 6.01: point2(1) = 5: point2(2) = 0
    location(0) = 5: location(1) = 8: location(2) = 0
    dimObj.UnitsFormat = acDimLArchitectural
    ' Enable and setup tolerance display
    dimObj.ToleranceDisplay = acTolLimits
    dimObj.ToleranceLowerLimit = -0.0001: dimObj.ToleranceUpperLimit = 0.0001
    ZoomAll
Toggle:
    Select Case MsgBox("Press OK to toggle the display of zero feet in the dimension tolerance", vbOKCancel)
        Case vbOK
            ' Toggle the display of zero feet for the dimension tolerance value
            dimObj.ToleranceSuppressZeroFeet = Not (dimObj.ToleranceSuppressZeroFeet)
        Case vbCancel
            Exit Sub
    End Select
    GoTo Toggle
(defun c:Example_ToleranceSuppressZeroFeet()
    ;; uses ToleranceSuppressZeroFeet to toggle the display of zeros feet
    ;; in the dimension tolerance display
    ;; Define the dimension
          point2 (vlax-3d-point 6.01 5 0)
          location (vlax-3d-point 5 8 0))
    (vla-put-UnitsFormat dimObj acDimLArchitectural)
    ;; Enable and setup tolerance display
    (vla-put-ToleranceDisplay dimObj acTolLimits)
    (vla-put-ToleranceLowerLimit dimObj -0.0001)
    (vla-put-ToleranceUpperLimit dimObj 0.0001)
    (vla-ZoomAll acadObj)
    ;; Toggle the display of zero feet for the dimension tolerance value
    (vla-put-ToleranceSuppressZeroFeet dimObj (if (= (vla-get-ToleranceSuppressZeroFeet dimObj) :vlax-true) :vlax-false :vlax-true))
    (alert "Suppression of zero feet toggled.")
    ;; Toggle the display of zero feet for the dimension tolerance value back to previous state
    (alert "Suppression of zero feet toggled back.")
GMT+8, 2026-10-27 04:52
