ToleranceSuppressLeadingZeros 属性 (ActiveX)
2024-5-18 16:55| 发布者: admin| 查看: 784| 评论: 0|原作者: admin|来自: AutoCAD
指定隐含公差值中的前导零点。
object.ToleranceSuppressLeadingZeros
类型:Dim3PointAngular、DimAligned、DimAngular、DimArcLength、DimDiametric、Dimension、DimOrdinate、DimRadial、DimRadialLarge、DimRotated
此属性应用于的对象。
只读:不
类型:布尔
  • True:禁止十进制值中的前导零。例如,0.5000 变为 .5000。
  • False:不要禁止十进制值中的前导零。
此属性的初始值为 。False
注意:此值将覆盖 DIMTZIN 系统变量的值。
Sub Example_ToleranceSuppressLeadingZeros()
    ' uses ToleranceSuppressLeadingZeros to toggle the display of leading zeros
    ' in the dimension tolerance display
    Dim dimObj As AcadDimAligned
    ' Define the dimension
    point2(0) = 5.01: point2(1) = 5: point2(2) = 0
    ' Enable and setup tolerance display
    dimObj.ToleranceDisplay = acTolSymmetrical
    dimObj.ToleranceLowerLimit = -0.0001: dimObj.ToleranceUpperLimit = 0.005
Toggle:
    Select Case MsgBox("Press OK to toggle the display of leading zeros in the dimension tolerance", vbOKCancel)
        Case vbOK
            ' Toggle the display of leading zeros for the dimension tolerance value
            dimObj.ToleranceSuppressLeadingZeros = Not (dimObj.ToleranceSuppressLeadingZeros)
        Case vbCancel
            Exit Sub
    End Select
    GoTo Toggle
(defun c:Example_ToleranceSuppressLeadingZeros()
    ;; uses ToleranceSuppressLeadingZeros to toggle the display of leading zeros
    ;; in the dimension tolerance display
    ;; Define the dimension
          point2 (vlax-3d-point 5.01 5 0)
    ;; Enable and setup tolerance display
    (vla-put-ToleranceDisplay dimObj acTolSymmetrical)
    (vla-put-ToleranceLowerLimit dimObj -0.0001)
    (vla-put-ToleranceUpperLimit dimObj 0.005)
    (vla-ZoomAll acadObj)
    ;; Toggle the display of leading zeros for the dimension tolerance value
    (vla-put-ToleranceSuppressLeadingZeros dimObj (if (= (vla-get-ToleranceSuppressLeadingZeros dimObj) :vlax-true) :vlax-false :vlax-true))
    (alert "Suppression of leading zeros toggled.")
    ;; Toggle the display of leading zeros for the dimension tolerance value back to previous state
    (alert "Suppression of leading zeros toggled back.")
GMT+8, 2026-10-27 05:05
