ToleranceHeightScale 属性 (ActiveX)
指定公差值的文本高度相对于尺寸文本高度的比例因子。 支持的平台:仅限 Windows 签名VBA: object.ToleranceHeightScale 属性值只读:不 类型:双 公差值的比例因子。 言论此属性的初始值为 1.0000。 仅当该属性设置为除 以外的任何值时,此属性才可用。ToleranceDisplayacTolNone 当 DIMTOL 处于打开状态且 DIMTM 不等于 DIMTP 时,或者当 DIMLIM 处于打开状态时,将此属性用于正负容差字符串。 注意:此属性将覆盖给定维度的 DIMTFAC 系统变量的值。
例子VBA: Sub Example_ToleranceHeightScale()
' turns on the tolerance display for the new dimension. The height
' of the tolerance text can then be adjusted by the user
Dim dimObj As AcadDimAligned
Dim newText As AcadTextStyle
Dim CurrentScale As Integer
' Define the dimension
point2(0) = 5.5: point2(1) = 5: point2(2) = 0
' Turn on the tolerance display
dimObj.ToleranceDisplay = acTolSymmetrical
Increase:
' Read and display the current tolerance height scale for this dimension
If MsgBox("The tolerance height scale is currently set to: " & dimObj.ToleranceHeightScale & vbCrLf & _
"Press OK to increase, or cancel to finish", vbOKCancel) = vbCancel Then
Exit Sub
End If
' Increase the tolerance height scale for this dimension
dimObj.ToleranceHeightScale = dimObj.ToleranceHeightScale + 1
GoTo Increase
可视化 LISP: (vl-load-com)
(defun c:Example_ToleranceHeightScale()
;; turns on the tolerance display for the new dimension. The height
;; of the tolerance text can then be adjusted by the user
;; Define the dimension
point2 (vlax-3d-point 5.5 5 0)
;; Turn on the tolerance display
(vla-put-ToleranceDisplay dimObj acTolSymmetrical)
(vla-ZoomAll acadObj)
;; Read and display the current tolerance height scale for this dimension
(alert (strcat "The tolerance height scale is currently set to: " (rtos (vla-get-ToleranceHeightScale dimObj) 2)))
;; Increase the tolerance height scale for this dimension
(vla-put-ToleranceHeightScale dimObj (1+ (vla-get-ToleranceHeightScale dimObj)))
(alert (strcat "The tolerance height scale is now set to: " (rtos (vla-get-ToleranceHeightScale dimObj) 2)))
GMT+8, 2026-10-27 01:21
