ToleranceDisplay 属性 (ActiveX)
2024-5-18 16:55| 发布者: admin| 查看: 743| 评论: 0|原作者: admin|来自: AutoCAD
指定公差是否与尺寸文本一起显示。
object.ToleranceDisplay
类型:Dim3PointAngular、DimAligned、DimAngular、DimArcLength、DimDiametric、Dimension、DimOrdinate、DimRadial、DimRadialLarge、DimRotated
此属性应用于的对象。
只读:不
类型:枚举acDimToleranceMethod
  • acTolNone
  • acTolSymmetrical
  • acTolDeviation
  • acTolLimits
  • acTolBasic
此属性的初始值为 。acTolNone
注意:此属性将覆盖给定维度的 DIMTOL 系统变量的值。
Sub Example_ToleranceDisplay()
    ' turns on the tolerance display for the new dimension
    Dim dimObj As AcadDimAligned
    Dim newText As AcadTextStyle
    Dim CurrentDisplay As String
    ' Define the dimension
    point2(0) = 5.5: point2(1) = 5: point2(2) = 0
    ' Read and display the current tolerance display for this dimension
    CurrentDisplay = IIf(dimObj.ToleranceDisplay = acTolNone, "Hidden", "Visible")
    MsgBox "The tolerance display is currently: " & CurrentDisplay
    ' Toggle the tolerance display for this dimension
    If dimObj.ToleranceDisplay = acTolNone Then
        dimObj.ToleranceDisplay = acTolSymmetrical
        CurrentDisplay = "Symmetrical"
    Else
        CurrentDisplay = "None"
    End If
    ' Display the current tolerance display for this dimension
    MsgBox "The tolerance display is now set to: " & CurrentDisplay
(defun c:Example_ToleranceDisplay()
    ;; turns on the tolerance display for the new dimension
    ;; Define the dimension
          point2 (vlax-3d-point 5.5 5 0)
    (vla-ZoomAll acadObj)
    ;; Read and display the current tolerance display for this dimension
    (setq currentDisplay (if (= (vla-get-ToleranceDisplay dimObj) acTolNone) "Hidden" "Visible"))
    (alert (strcat "The tolerance display is currently: " currentDisplay))
    ;; Toggle the tolerance display for this dimension
        (progn
            (vla-put-ToleranceDisplay dimObj acTolSymmetrical)
            (setq currentDisplay "Symmetrical")
        (progn
            (vla-put-ToleranceDisplay dimObj acTolNone)
            (setq currentDisplay "None")
    ;; Display the current tolerance display for this dimension
    (alert (strcat "The tolerance display is now set to: " currentDisplay))
GMT+8, 2026-10-27 00:38
