您可以通过裁剪图像来定义图像的显示和绘图区域。剪切边界必须是 2D 多边形或矩形,其顶点被约束为位于图像边界内。同一图像的多个实例可以具有不同的边界。 如果要显示或隐藏图像边界,请使用该属性,并使用该属性确定剪切边界是定义为矩形还是多边形。IsClippedClipBoundaryType 使用以下方法获取或设置图像的剪切边界:
裁剪光栅图像本示例在模型空间中添加光栅图像,然后根据裁剪边界裁剪该图像。此示例使用在 VBA 示例目录中找到的 WorldMap.tif 文件。如果没有此映像,或者它位于其他目录中,请修改代码以使用有效的路径和文件名。 VB.NETImports Autodesk.AutoCAD.Runtime
<CommandMethod("ClippingRasterBoundary")> _
Public Sub ClippingRasterBoundary()
' Get the current database and start a transaction
Dim acCurDb As Autodesk.AutoCAD.DatabaseServices.Database
acCurDb = Application.DocumentManager.MdiActiveDocument.Database
' Define the name and image to use
Dim strImgName As String = "WorldMap"
Dim strFileName As String = "C:\AutoCAD\Sample\VBA\WorldMap.TIF"
Dim acRasterDef As RasterImageDef
Dim bRasterDefCreated As Boolean = False
Dim acImgDefId As ObjectId
' Get the image dictionary
Dim acImgDctID As ObjectId = RasterImageDef.GetImageDictionary(acCurDb)
' Check to see if the dictionary does not exist, it not then create it
If acImgDctID.IsNull Then
acImgDctID = RasterImageDef.CreateImageDictionary(acCurDb)
End If
' Open the image dictionary
Dim acImgDict As DBDictionary = acTrans.GetObject(acImgDctID, OpenMode.ForRead)
' Check to see if the image definition already exists
If acImgDict.Contains(strImgName) Then
acImgDefId = acImgDict.GetAt(strImgName)
acRasterDef = acTrans.GetObject(acImgDefId, OpenMode.ForWrite)
Else
' Create a raster image definition
Dim acRasterDefNew As New RasterImageDef
' Set the source for the image file
acRasterDefNew.SourceFileName = strFileName
' Load the image into memory
acRasterDefNew.Load()
' Add the image definition to the dictionary
acTrans.GetObject(acImgDctID, OpenMode.ForWrite)
acImgDefId = acImgDict.SetAt(strImgName, acRasterDefNew)
acTrans.AddNewlyCreatedDBObject(acRasterDefNew, True)
acRasterDef = acRasterDefNew
bRasterDefCreated = True
End If
' Open the Block table for read
Dim acBlkTbl As BlockTable
acBlkTbl = acTrans.GetObject(acCurDb.BlockTableId, OpenMode.ForRead)
' Open the Block table record Model space for write
OpenMode.ForWrite)
' Create the new image and assign it the image definition
Using acRaster As New RasterImage
acRaster.ImageDefId = acImgDefId
' Use ImageWidth and ImageHeight to get the size of the image in pixels (1024 x 768).
' Use ResolutionMMPerPixel to determine the number of millimeters in a pixel so you
' can convert the size of the drawing into other units or millimeters based on the
' drawing units used in the current drawing.
' Define the width and height of the image
Dim width As Vector3d
Dim height As Vector3d
' Check to see if the measurement is set to English (Imperial) or Metric units
If acCurDb.Measurement = MeasurementValue.English Then
width = New Vector3d((acRasterDef.ResolutionMMPerPixel.X * acRaster.ImageWidth) / 25.4, 0, 0)
height = New Vector3d(0, (acRasterDef.ResolutionMMPerPixel.Y * acRaster.ImageHeight) / 25.4, 0)
Else
width = New Vector3d(acRasterDef.ResolutionMMPerPixel.X * acRaster.ImageWidth, 0, 0)
height = New Vector3d(0, acRasterDef.ResolutionMMPerPixel.Y * acRaster.ImageHeight, 0)
End If
' Define the position for the image
Dim insPt As New Point3d(5.0, 5.0, 0.0)
' Define and assign a coordinate system for the image's orientation
Dim coordinateSystem As New CoordinateSystem3d(insPt, width * 2, height * 2)
acRaster.Orientation = coordinateSystem
' Set the rotation angle for the image
acRaster.Rotation = 0
' Define the clipping boundary in drawing units
Dim acPt2dColl As New Point2dCollection
Dim acMat3d As Matrix3d = acRaster.PixelToModelTransform.Inverse()
acPt2dColl.Add(New Point3d(5.5, 15, 0).TransformBy(acMat3d).Convert2d(New Plane()))
acPt2dColl.Add(New Point3d(12.5, 15, 0).TransformBy(acMat3d).Convert2d(New Plane()))
acPt2dColl.Add(New Point3d(12.5, 10.5, 0).TransformBy(acMat3d).Convert2d(New Plane()))
acPt2dColl.Add(New Point3d(5.5, 10.5, 0).TransformBy(acMat3d).Convert2d(New Plane()))
' Clip the image
acRaster.SetClipBoundary(ClipBoundaryType.Rectangle, acPt2dColl)
' Enable the display of the clip
acRaster.IsClipped = True
' Add the new object to the block table record and the transaction
acBlkTblRec.AppendEntity(acRaster)
acTrans.AddNewlyCreatedDBObject(acRaster, True)
' Connect the raster definition and image together so the definition
' does not appear as "unreferenced" in the External References palette.
RasterImage.EnableReactors(True)
acRaster.AssociateRasterDef(acRasterDef)
If bRasterDefCreated Then
acRasterDef.Dispose()
End If
End Using
' Save the new object to the database
acTrans.Commit()
' Dispose of the transaction
End Using
[CommandMethod("ClippingRasterBoundary")]
public void ClippingRasterBoundary()
// Get the current database and start a transaction
Database acCurDb;
acCurDb = Application.DocumentManager.MdiActiveDocument.Database;
// Define the name and image to use
string strImgName = "WorldMap";
string strFileName = "C:\\AutoCAD\\Sample\\VBA\\WorldMap.TIF";
RasterImageDef acRasterDef;
bool bRasterDefCreated = false;
ObjectId acImgDefId;
// Get the image dictionary
ObjectId acImgDctID = RasterImageDef.GetImageDictionary(acCurDb);
// Check to see if the dictionary does not exist, it not then create it
if (acImgDctID.IsNull)
acImgDctID = RasterImageDef.CreateImageDictionary(acCurDb);
// Open the image dictionary
DBDictionary acImgDict = acTrans.GetObject(acImgDctID, OpenMode.ForRead) as DBDictionary;
// Check to see if the image definition already exists
if (acImgDict.Contains(strImgName))
acImgDefId = acImgDict.GetAt(strImgName);
acRasterDef = acTrans.GetObject(acImgDefId, OpenMode.ForWrite) as RasterImageDef;
else
// Create a raster image definition
RasterImageDef acRasterDefNew = new RasterImageDef();
// Set the source for the image file
acRasterDefNew.SourceFileName = strFileName;
// Load the image into memory
acRasterDefNew.Load();
// Add the image definition to the dictionary
acTrans.GetObject(acImgDctID, OpenMode.ForWrite);
acImgDefId = acImgDict.SetAt(strImgName, acRasterDefNew);
acTrans.AddNewlyCreatedDBObject(acRasterDefNew, true);
acRasterDef = acRasterDefNew;
bRasterDefCreated = true;
BlockTable acBlkTbl;
acBlkTbl = acTrans.GetObject(acCurDb.BlockTableId, OpenMode.ForRead) as BlockTable;
BlockTableRecord acBlkTblRec;
// Create the new image and assign it the image definition
using (RasterImage acRaster = new RasterImage())
acRaster.ImageDefId = acImgDefId;
// Use ImageWidth and ImageHeight to get the size of the image in pixels (1024 x 768).
// Use ResolutionMMPerPixel to determine the number of millimeters in a pixel so you
// can convert the size of the drawing into other units or millimeters based on the
// drawing units used in the current drawing.
// Define the width and height of the image
Vector3d width;
Vector3d height;
// Check to see if the measurement is set to English (Imperial) or Metric units
if (acCurDb.Measurement == MeasurementValue.English)
width = new Vector3d((acRasterDef.ResolutionMMPerPixel.X * acRaster.ImageWidth) / 25.4, 0, 0);
height = new Vector3d(0, (acRasterDef.ResolutionMMPerPixel.Y * acRaster.ImageHeight) / 25.4, 0);
else
width = new Vector3d(acRasterDef.ResolutionMMPerPixel.X * acRaster.ImageWidth, 0, 0);
height = new Vector3d(0, acRasterDef.ResolutionMMPerPixel.Y * acRaster.ImageHeight, 0);
// Define the position for the image
Point3d insPt = new Point3d(5.0, 5.0, 0.0);
// Define and assign a coordinate system for the image's orientation
CoordinateSystem3d coordinateSystem = new CoordinateSystem3d(insPt, width * 2, height * 2);
acRaster.Orientation = coordinateSystem;
// Set the rotation angle for the image
acRaster.Rotation = 0;
// Define the clipping boundary in drawing units
Point2dCollection acPt2dColl = new Point2dCollection();
Matrix3d acMat3d = acRaster.PixelToModelTransform.Inverse();
acPt2dColl.Add(new Point3d(5.5, 15, 0).TransformBy(acMat3d).Convert2d(new Plane()));
acPt2dColl.Add(new Point3d(12.5, 15, 0).TransformBy(acMat3d).Convert2d(new Plane()));
acPt2dColl.Add(new Point3d(12.5, 10.5, 0).TransformBy(acMat3d).Convert2d(new Plane()));
acPt2dColl.Add(new Point3d(5.5, 10.5, 0).TransformBy(acMat3d).Convert2d(new Plane()));
// Clip the image
acRaster.SetClipBoundary(ClipBoundaryType.Rectangle, acPt2dColl);
// Enable the display of the clip
acRaster.IsClipped = true;
acBlkTblRec.AppendEntity(acRaster);
acTrans.AddNewlyCreatedDBObject(acRaster, true);
// Connect the raster definition and image together so the definition
// does not appear as "unreferenced" in the External References palette.
RasterImage.EnableReactors(true);
acRaster.AssociateRasterDef(acRasterDef);
if (bRasterDefCreated)
acRasterDef.Dispose();
// Save the new object to the database
acTrans.Commit();
// Dispose of the transaction
VBA/ActiveX 代码参考Sub ClippingRasterBoundary()
Dim scalefactor As Double
Dim rotationAngle As Double
Dim imageName As String
Dim rasterObj As AcadRasterImage
imageName = "C:/AutoCAD/sample/VBA/WorldMap.TIF"
insertionPoint(0) = 5
insertionPoint(1) = 5
insertionPoint(2) = 0
scalefactor = 2
rotationAngle = 0
' Creates a raster image in model space
Set rasterObj = ThisDrawing.ModelSpace.AddRaster(imageName, insertionPoint, _
scalefactor, rotationAngle)
' Establish the clip boundary with an array of points
Dim clipPoints(0 To 9) As Double
clipPoints(0) = 5.5: clipPoints(1) = 15
clipPoints(2) =12.5: clipPoints(3) = 15
clipPoints(4) = 12.5: clipPoints(5) = 10.5
clipPoints(6) = 5.5: clipPoints(7) = 10.5
clipPoints(8) = 5.5: clipPoints(9) = 15
' Clip the image
rasterObj.ClipBoundary clipPoints
rasterObj.ClippingEnabled = True
ThisDrawing.Regen acActiveViewport
父主题: |
GMT+8, 2026-10-28 17:35
