Thickness 属性 (ActiveX)
2024-5-18 16:55| 发布者: admin| 查看: 786| 评论: 0|原作者: admin|来自: AutoCAD
指定 2D AutoCAD 对象在其高程上方或下方拉伸的距离。
object.Thickness
类型:圆弧、属性、属性参照、圆、线、LWPolyline、点、折线、形状、实体、文本、迹线
此属性应用于的对象。
只读:不
类型:双
默认值为 0.0。
更改对象的厚度会更改其 Z 方向厚度。
更改 3D 折线、尺寸或浮动视口的粗细不起作用。
Sub Example_Thickness()
    ' This example creates a circle in model space
    ' and changes the thickness of the circle.
    Dim circleObj As AcadCircle
    Dim radius As Double
    ' Define the circle
    centerPoint(0) = 0#: centerPoint(1) = 0#: centerPoint(2) = 0#
    radius = 5#
    ' Create the Circle object in model space
    Set circleObj = ThisDrawing.ModelSpace.AddCircle(centerPoint, radius)
    ZoomAll
    ' Find the current thickness of the circle
    Dim currThickness As Double
    currThickness = circleObj.Thickness
    MsgBox "The thickness of the circle is " & circleObj.Thickness, vbInformation, "Thickness Example"
    ' Change the thickness of the circle
    circleObj.Thickness = currThickness + 3
    circleObj.Update
    ' Change the direction of the viewport so that you can
    ' view the change made to the thickness. Once you change
    ' the direction, you must reset the active viewport.
    Dim NewDirection(0 To 2) As Double
    NewDirection(0) = -1: NewDirection(1) = -1: NewDirection(2) = 1
    ThisDrawing.ActiveViewport.direction = NewDirection
    ThisDrawing.ActiveViewport = ThisDrawing.ActiveViewport
    MsgBox "The thickness of the circle is now " & circleObj.Thickness, vbInformation, "Thickness Example"
(defun c:Example_Thickness()
    ;; This example creates a circle in model space
    ;; and changes the thickness of the circle.
    ;; Define the circle
    (setq centerPoint (vlax-3d-point 0 0 0)
          radius 5)
    ;; Create the Circle object in model space
    (setq circleObj (vla-AddCircle modelSpace centerPoint radius))
    (vla-ZoomAll acadObj)
    ;; Find the current thickness of the circle
    (setq currThickness (vla-get-Thickness circleObj))
    (alert (strcat "The thickness of the circle is " (rtos currThickness 2)))
    ;; Change the thickness of the circle
    (vla-put-Thickness circleObj (+ currThickness 3))
    (vla-Update circleObj)
    ;; Change the direction of the viewport so that you can
    ;; view the change made to the thickness. Once you change
    ;; the direction, you must reset the active viewport.
    (setq NewDirection (vlax-3d-point -1 -1 1))
    (setq activeViewport (vla-get-ActiveViewport doc))
    (vla-put-Direction activeViewport NewDirection)
    (vla-put-ActiveViewport doc activeViewport)
    (alert (strcat "The thickness of the circle is now " (rtos (vla-get-Thickness circleObj) 2)))
GMT+8, 2026-10-27 03:34
