TextureMapPath 属性 (ActiveX)
指定 AutoCAD 在其中搜索渲染纹理贴图的目录。 支持的平台:仅限 Windows 属性值只读:不 类型:字符串 用于渲染纹理贴图的目录的位置。 言论可以使用分号 (;) to paths 输入多个路径。 例子VBA: Sub Example_TextureMapPath()
' TextureMapPath. It then changes the value, and finally
Dim currTextureMapPath As String
Dim newTextureMapPath As String
Set preferences = ThisDrawing.Application.Preferences
' Retrieve the current TextureMapPath value
currTextureMapPath = preferences.Files.TextureMapPath
MsgBox "The current value for TextureMapPath is " & currTextureMapPath, vbInformation, "TextureMapPath Example"
' Change the value for TextureMapPath
newTextureMapPath = "TestTextureMapPath"
preferences.Files.TextureMapPath = newTextureMapPath
MsgBox "The new value for TextureMapPath is " & newTextureMapPath, vbInformation, "TextureMapPath Example"
' Reset TextureMapPath to its original value
preferences.Files.TextureMapPath = currTextureMapPath
MsgBox "The TextureMapPath value is reset to " & currTextureMapPath, vbInformation, "TextureMapPath Example"
可视化 LISP: (vl-load-com)
(defun c:Example_TextureMapPath()
;; TextureMapPath. It then changes the value, and finally
;; Retrieve the current TextureMapPath value
(setq currTextureMapPath (vla-get-TextureMapPath (vla-get-Files preferences)))
(alert (strcat "The current value for TextureMapPath is " currTextureMapPath))
;; Change the value for TextureMapPath
(setq newTextureMapPath "TestTextureMapPath")
(vla-put-TextureMapPath (vla-get-Files preferences) newTextureMapPath)
(alert (strcat "The new value for TextureMapPath is " newTextureMapPath))
;; Reset TextureMapPath to its original value
(vla-put-TextureMapPath (vla-get-Files preferences) currTextureMapPath)
(alert (strcat "The TextureMapPath value is reset to " currTextureMapPath))
GMT+8, 2026-10-27 05:21
