TextSuffix 属性 (ActiveX)
2024-5-18 16:55| 发布者: admin| 查看: 819| 评论: 0|原作者: admin|来自: AutoCAD
指定维度值后缀。
object.TextSuffix
类型:Dim3PointAngular、DimAligned、DimAngular、DimArcLength、DimDiametric、Dimension、DimOrdinate、DimRadial、DimRadialLarge、DimRotated
此属性应用于的对象。
只读:不
类型:字符串
维度值的后缀。
此属性的初始值为“”。
注意:此属性将覆盖给定维度的 DIMPOST 系统变量的值。
Sub Example_TextSuffix()
    ' uses TextSuffix to allow the user to change the text suffix for the
    ' dimension
    Dim dimObj As AcadDimAligned
    Dim suffix As String
    ' Define the dimension
    point1(0) = 0: point1(1) = 5: point1(2) = 0
    point2(0) = 5: point2(1) = 5: point2(2) = 0
    ' Allow the user to change the text suffix for the dimension
    suffix = InputBox("Enter a new text suffix for the dimension", "Set Dimension Suffix", ":SUFFIX")
    dimObj.TextSuffix = suffix   ' Commit changes to suffix
    ' Read back and display the dimension text suffix
    suffix = dimObj.TextSuffix
    If suffix <> "" Then
        MsgBox "The suffix of the dimension has been changed to: " & suffix
    Else
        MsgBox "The suffix of the dimension has been removed"
    End If
(defun c:Example_TextSuffix()
    ;; uses TextSuffix to allow the user to change the text suffix for the
    ;; dimension
    ;; Define the dimension
    (setq point1 (vlax-3d-point 0 5 0)
          point2 (vlax-3d-point 5 5 0)
    (vla-ZoomAll acadObj)
    ;; Allow the user to change the text suffix for the dimension
    (setq suffix (vla-GetString (vla-get-Utility doc) :vlax-false "\nEnter a new text suffix for the dimension: "))
    (vla-put-TextSuffix dimObj suffix)   ;; Commit changes to suffix
    ;; Read back and display the dimension text suffix
    (setq suffix (vla-get-TextSuffix dimObj))
    (if (/= suffix "")
        (alert (strcat "The suffix of the dimension has been changed to: " suffix))
        (alert "The suffix of the dimension has been removed")
GMT+8, 2026-10-27 03:02
