TextStyleName 属性 (ActiveX)
指定 MText 的样式名称。 支持的平台:仅限 Windows 属性值只读:不 类型:字符串 对象的样式名称。 言论没有其他评论。 例子VBA: Sub Example_TextManipulation()
Dim oML As AcadMLeader
Dim points(0 To 14) As Double
' Define the leader points
points(0) = 1: points(1) = 1: points(2) = 0
points(3) = 1: points(4) = 2: points(5) = 0
points(6) = 2: points(7) = 2: points(8) = 0
points(9) = 3: points(10) = 2: points(11) = 0
points(12) = 4: points(13) = 4: points(14) = 0
Dim i As Long
Set oML = ThisDrawing.ModelSpace.AddMLeader(points, i)
oML.TextLeftAttachmentType = acAttachmentBottomLine
oML.TextRightAttachmentType = acAttachmentMiddleOfBottom
oML.TextBackgroundFill = False
oML.TextDirection = acLeftToRight
oML.TextHeight = 2.3
oML.TextJustify = acAttachmentPointMiddleLeft
oML.TextLineSpacingDistance = 2.4
oML.TextLineSpacingFactor = 1.2
oML.TextLineSpacingStyle = acLineSpacingStyleExactly
oML.TextWidth = 7.4
可视化 LISP: (vl-load-com)
(defun c:Example_TextManipulation()
;; Define the leader points
(setq points (vlax-make-safearray vlax-vbDouble '(0 . 14)))
(vlax-safearray-fill points '(1 1 0
1 2 0
2 2 0
3 2 0
4 4 0
(setq i 0)
(setq oML (vla-AddMLeader modelSpace points i))
(vla-put-TextLeftAttachmentType oML acAttachmentBottomLine)
(vla-put-TextRightAttachmentType oML acAttachmentMiddleOfBottom)
(vla-put-TextBackgroundFill oML :vlax-false)
(vla-put-TextDirection oML acLeftToRight)
(vla-put-TextHeight oML 2.3)
(vla-put-TextJustify oML acAttachmentPointMiddleLeft)
(vla-put-TextLineSpacingDistance oML 2.4)
(vla-put-TextLineSpacingFactor oML 1.2)
(vla-put-TextLineSpacingStyle oML acLineSpacingStyleExactly)
(vla-put-TextWidth oML 7.4)
GMT+8, 2026-10-27 05:42
