TextString 属性 (ActiveX)
指定实体的文本字符串。 支持的平台:仅限 Windows 签名VBA: object.TextString
属性值只读:不 类型:字符串 最大长度为 256 个字符。 言论AttributeReference:这等效于 AutoCAD 中属性的值。 GeoPositionMarker、MText:文本字符串可能包含格式代码。您可以添加下划线、在文本上添加一行以及创建堆叠文本。您还可以更改颜色、字体和文本高度。您可以更改文本字符之间的空格或增加字符本身的宽度。应用格式设置,或分析现有文本字符串的格式。 例子VBA: Sub Example_TextString()
' This example creates a text object in model space.
' It then returns the text string for that object.
Dim textObj As AcadText
Dim text As String
Dim height As Double
' Define the text object
text = "Hello, World."
insertionPoint(0) = 2: insertionPoint(1) = 2: insertionPoint(2) = 0
height = 0.5
' Create the text object in model space
Set textObj = ThisDrawing.ModelSpace.AddText(text, insertionPoint, height)
ZoomAll
' Return the current text string for the object
text = textObj.textString
MsgBox "The TextString property equals: " & text, vbInformation, "TextString Example"
可视化 LISP: (vl-load-com)
(defun c:Example_TextString()
;; This example creates a text object in model space.
;; It then returns the text string for that object.
;; Define the text object
(setq insertionPoint (vlax-3d-point 2 2 0)
textString "Hello, World."
height 0.5)
;; Create the text object in model space
(setq textObj (vla-AddText modelSpace textString insertionPoint height))
(vla-ZoomAll acadObj)
;; Return the current text string for the object
(setq text (vla-get-TextString textObj))
(alert (strcat "The TextString property equals: " text))
GMT+8, 2026-10-27 00:36
