TextInsideAlign 属性 (ActiveX)
指定除纵坐标外的所有尺寸类型的延伸线内尺寸文本的位置。 支持的平台:仅限 Windows 签名VBA: object.TextInsideAlign
属性值只读:不 类型:布尔
言论此属性的初始值为 。True 仅当该属性设置为 时,此属性才可用。TextInsideTrue 注意:此属性将覆盖给定维度的 DIMTIH 系统变量的值。
例子VBA: Sub Example_TextInsideAlign()
' allows the user to toggle the TextInsideAlign value for the dimension
Dim dimObj As AcadDimAligned
' Define the dimension
point2(0) = 5.5: point2(1) = 6: point2(2) = 0
dimObj.TextInside = True ' The TextInsideAlign property will only work
' when this property is active
Toggle:
Select Case MsgBox("Press OK to toggle the TextInsideAlign value for this dimension", vbOKCancel)
Case vbOK
' Toggle the TextInsideAlign value for this dimension
dimObj.TextInsideAlign = Not (dimObj.TextInsideAlign)
' Read and display the new dimension TextInsideAlign value
MsgBox "TextInsideAlign is currently set to: " & dimObj.TextInsideAlign
Case vbCancel
Exit Sub
End Select
GoTo Toggle
可视化 LISP: (vl-load-com)
(defun c:Example_TextInsideAlign()
;; allows the user to toggle the TextInsideAlign value for the dimension
;; Define the dimension
point2 (vlax-3d-point 5.5 6 0)
(vla-put-TextInside dimObj :vlax-true) ;; The TextInsideAlign property will only work
;; when this property is active
(vla-ZoomAll acadObj)
;; Toggle the TextInsideAlign value for this dimension
(vla-put-TextInsideAlign dimObj (if (= (vla-get-TextInsideAlign dimObj) :vlax-true) :vlax-false :vlax-true))
;; Read and display the new dimension TextInsideAlign value
(alert (strcat "TextInsideAlign is currently set to: " (if (= (vla-get-TextInsideAlign dimObj) :vlax-true) "True" "False")))
GMT+8, 2026-10-28 12:59
