TextInside 属性 (ActiveX)
2024-5-18 16:55| 发布者: admin| 查看: 754| 评论: 0|原作者: admin|来自: AutoCAD
指定是否要在扩展线内绘制尺寸文本。
object.TextInside
类型:Dim3PointAngularDimAlignedDimAngularDimArcLengthDimDiametricDimRadialDimRadialLargeDimRotated
此属性应用于的对象。
只读:
类型:布尔
  • True:强制在扩展线之间显示尺寸文本。
  • False:仅当有足够的空间时,才在延长线内绘制尺寸文本。
此属性的初始值为 。True
将此属性设置为具有不同的结果。对于线性尺寸和角度尺寸,如果有足够的空间,AutoCAD 会将文本放置在扩展线内。对于不适合圆或圆弧的半径和直径尺寸,此属性不起作用,并且始终强制文本超出圆或圆弧。False
注意:此属性将覆盖给定维度的 DIMTIX 系统变量的值。
Sub Example_TextInside()
    ' allows the user to toggle, forcing the dimension text between the extension lines
    ' using the TextInside property
    Dim dimObj As AcadDimAligned
    Dim CurrentValue As String
    ' Define the dimension
    point2(0) = 5.5: point2(1) = 5: point2(2) = 0
Toggle:
    Select Case MsgBox("Press OK to toggle forcing the dimension text inside the extension lines", vbOKCancel)
        Case vbOK
            ' Toggle forcing the dimension text inside the extension lines
            dimObj.TextInside = Not (dimObj.TextInside)
            ' Read and display the new dimension TextInside value
            CurrentValue = IIf(dimObj.TextInside, "is now", "is not")
            MsgBox "The dimension text " & CurrentValue & " forced inside the extension lines"
        Case vbCancel
            Exit Sub
    End Select
    GoTo Toggle
(defun c:Example_TextInside()
    ;; allows the user to toggle, forcing the dimension text between the extension lines
    ;; using the TextInside property
    ;; Define the dimension
          point2 (vlax-3d-point 5.5 5 0)
    (vla-ZoomAll acadObj)
    ;; Toggle forcing the dimension text inside the extension lines
    (vla-put-TextInside dimObj (if (= (vla-get-TextInside dimObj) :vlax-true) :vlax-false :vlax-true))
    ;; Read and display the new dimension TextInside value
    (setq CurrentValue (if (= (vla-get-TextInside dimObj) :vlax-true) "is now" "is not"))
    (alert (strcat "The dimension text " CurrentValue " forced inside the extension lines"))
GMT+8, 2026-9-9 15:44
