TextGenerationFlag 属性 (ActiveX)
指定属性文本生成标志。 支持的平台:仅限 Windows 属性值只读:不 类型:枚举acTextGenerationFlag
言论若要指定这两个标志,请将它们相加。 例子VBA: Sub Example_TextGenerationFlag()
' This example creates a text object in model space.
' It then changes the TextGenerationFlag of the text object.
Dim textObj As AcadText
Dim textString As String
Dim height As Double
' Define the text object
textString = "Hello, World."
insertionPoint(0) = 3: insertionPoint(1) = 3: insertionPoint(2) = 0
height = 0.5
' Create the text object in model space
Set textObj = ThisDrawing.ModelSpace.AddText(textString, insertionPoint, height)
ZoomAll
MsgBox "The TextGenerationFlag has not been set.", vbInformation, "TextGenerationFlag Example"
' Change the value of the TextGenerationFlag
textObj.TextGenerationFlag = acTextFlagBackward
ZoomAll
MsgBox "The TextGenerationFlag is set to acTextFlagBackward.", vbInformation, "TextGenerationFlag Example"
textObj.TextGenerationFlag = acTextFlagUpsideDown
ZoomAll
MsgBox "The TextGenerationFlag is set to acTextFlagUpsideDown.", vbInformation, "TextGenerationFlag Example"
textObj.TextGenerationFlag = acTextFlagBackward + acTextFlagUpsideDown
ZoomAll
MsgBox "The TextGenerationFlag is set to acTextFlagBackward + acTextFlagUpsideDown.", vbInformation, "TextGenerationFlag Example"
可视化 LISP: (vl-load-com)
(defun c:Example_TextGenerationFlag()
;; This example creates a text object in model space.
;; It then changes the TextGenerationFlag of the text object.
;; Define the text object
(setq insertionPoint (vlax-3d-point 3 3 0)
textString "Hello, World."
height 0.5)
;; Create the text object in model space
(setq textObj (vla-AddText modelSpace textString insertionPoint height))
(vla-ZoomAll acadObj)
(alert "The TextGenerationFlag has not been set.")
;; Change the value of the TextGenerationFlag
(vla-put-TextGenerationFlag textObj acTextFlagBackward)
(alert "The TextGenerationFlag is set to acTextFlagBackward.")
(vla-put-TextGenerationFlag textObj acTextFlagUpsideDown)
(alert "The TextGenerationFlag is set to acTextFlagUpsideDown.")
(vla-put-TextGenerationFlag textObj (+ acTextFlagBackward acTextFlagUpsideDown))
(alert "The TextGenerationFlag is set to acTextFlagBackward + acTextFlagUpsideDown.")
GMT+8, 2026-10-27 05:30
