TextGap 属性 (ActiveX)
指定在分割尺寸线以容纳尺寸文本时尺寸文本与尺寸线之间的距离。 支持的平台:仅限 Windows 签名VBA: object.TextGap 属性值只读:不 类型:双 指定间隙距离的实数。 言论此属性还设置对象上的批注和挂钩线之间的间隙。Leader 负值创建基本尺寸标注(文本周围带有框的尺寸文本)。 注意:此属性将覆盖给定维度的 DIMGAP 系统变量的值。
例子VBA: Sub Example_TextGap()
' uses the TextGap property to increase the distance between the
' dimension line and the dimension text
Dim dimObj As AcadDimAligned
' Define the dimension
point2(0) = 5.5: point2(1) = 5: point2(2) = 0
' Read and display current dimension gap
MsgBox "The dimension gap for this object is currently set to: " & dimObj.TextGap
' Increase the distance of the dimension gap
dimObj.TextGap = 0.5
MsgBox "The dimension gap for this object is now set to: " & dimObj.TextGap
可视化 LISP: (vl-load-com)
(defun c:Example_TextGap()
;; uses the TextGap property to increase the distance between the
;; dimension line and the dimension text
;; Define the dimension
point2 (vlax-3d-point 5.5 5 0)
(vla-ZoomAll acadObj)
;; Read and display current dimension gap
(alert (strcat "The dimension gap for this object is currently set to: " (rtos (vla-get-TextGap dimObj) 2)))
;; Increase the distance of the dimension gap
(vla-put-TextGap dimObj 0.5)
(alert (strcat "The dimension gap for this object is now set to: " (rtos (vla-get-TextGap dimObj) 2)))
GMT+8, 2026-10-27 07:15
