TextFontStyle 属性 (ActiveX)
指定新文本的字体样式。 支持的平台:仅限 Windows 属性值只读:不 类型:枚举acTextFontStyle
言论此属性的初始值为 。acFontRegular 例子VBA: Sub Example_TextFontStyle()
' TextFontStyle. It then changes the value, and finally
Dim currTextFontStyle As Integer
Dim constant As String
Dim newConstant As String
Set preferences = ThisDrawing.Application.Preferences
' Retrieve the current TextFontStyle value
currTextFontStyle = preferences.Display.TextFontStyle
constant = Choose(currTextFontStyle + 1, "acFontRegular", "acFontItalic", "acFontBold", "acFontBoldItalic")
MsgBox "The current value for TextFontStyle is " & constant, vbInformation, "TextFontStyle Example"
' Change the value for TextFontStyle
newConstant = "acFontBoldItalic"
preferences.Display.TextFontStyle = acFontBoldItalic
MsgBox "The new value for TextFontStyle is " & newConstant, vbInformation, "TextFontStyle Example"
' Reset TextFontStyle to its original value
preferences.Display.TextFontStyle = currTextFontStyle
MsgBox "The TextFontStyle value is reset to " & constant, vbInformation, "TextFontStyle Example"
可视化 LISP: (vl-load-com)
(defun c:Example_TextFontStyle()
;; TextFontStyle. It then changes the value, and finally
;; Retrieve the current TextFontStyle value
(setq currTextFontStyle (vla-get-TextFontStyle (vla-get-Display preferences)))
(setq constant (cond
((= currTextFontStyle acFontRegular) "acFontRegular")
((= currTextFontStyle acFontItalic) "acFontItalic")
((= currTextFontStyle acFontBold) "acFontBold")
((= currTextFontStyle acFontBoldItalic) "acFontBoldItalic")
(alert (strcat "The current value for TextFontStyle is " constant))
;; Change the value for TextFontStyle
(vla-put-TextFontStyle (vla-get-Display preferences) acFontBoldItalic)
(setq newTextFontStyle (vla-get-TextFontStyle (vla-get-Display preferences)))
(setq newConstant (cond
((= newTextFontStyle acFontRegular) "acFontRegular")
((= newTextFontStyle acFontItalic) "acFontItalic")
((= newTextFontStyle acFontBold) "acFontBold")
((= newTextFontStyle acFontBoldItalic) "acFontBoldItalic")
(alert (strcat "The new value for TextFontStyle is " newConstant))
;; Reset TextFontStyle to its original value
(vla-put-TextFontStyle (vla-get-Display preferences) currTextFontStyle)
(alert (strcat "The TextFontStyle value is reset to " constant))
GMT+8, 2026-10-27 08:59
