TextFontSize 属性 (ActiveX)
指定新文本的字体大小。 支持的平台:仅限 Windows 属性值只读:不 类型:整数 新文本的字体大小。字体大小的限制由字体决定。 言论此属性的初始值为 10。 例子VBA: Sub Example_TextFontSize()
' TextFontSize. It then changes the value, and finally
Dim currTextFontSize As Integer
Set preferences = ThisDrawing.Application.Preferences
' Retrieve the current TextFontSize value
currTextFontSize = preferences.Display.TextFontSize
MsgBox "The current value for TextFontSize is " & preferences.Display.TextFontSize, vbInformation, "TextFontSize Example"
' Change the value for TextFontSize
preferences.Display.TextFontSize = 12
MsgBox "The new value for TextFontSize is " & preferences.Display.TextFontSize, vbInformation, "TextFontSize Example"
' Reset TextFontSize to its original value
preferences.Display.TextFontSize = currTextFontSize
MsgBox "The TextFontSize value is reset to " & preferences.Display.TextFontSize, vbInformation, "TextFontSize Example"
可视化 LISP: (vl-load-com)
(defun c:Example_TextFontSize()
;; TextFontSize. It then changes the value, and finally
;; Retrieve the current TextFontSize value
(setq currTextFontSize (vla-get-TextFontSize (vla-get-Display preferences)))
(alert (strcat "The current value for TextFontSize is " (itoa currTextFontSize)))
;; Change the value for TextFontSize
(vla-put-TextFontSize (vla-get-Display preferences) 12)
(alert (strcat "The new value for TextFontSize is " (itoa (vla-get-TextFontSize (vla-get-Display preferences)))))
;; Reset TextFontSize to its original value
(vla-put-TextFontSize (vla-get-Display preferences) currTextFontSize)
(alert (strcat "The TextFontSize value is reset to " (itoa (vla-get-TextFontSize (vla-get-Display preferences)))))
GMT+8, 2026-10-27 01:21
