TextFont 属性 (ActiveX)
2024-5-18 16:55| 发布者: admin| 查看: 821| 评论: 0|原作者: admin|来自: AutoCAD
指定新文本的字体。
object.TextFont
类型:首选项显示
此属性应用于的对象。
只读:不
类型:字符串
新字体的名称。
此属性的初始值为 Courier。
Sub Example_TextFont()
    ' TextFont. It then changes the value, and finally
    Dim currTextFont As String
    Set preferences = ThisDrawing.Application.Preferences
    ' Retrieve the current TextFont value
    currTextFont = preferences.Display.TextFont
    MsgBox "The current value for TextFont is " & preferences.Display.TextFont, vbInformation, "TextFont Example"
    ' Change the value for TextFont
    preferences.Display.TextFont = "TestTextFont"
    MsgBox "The new value for TextFont is " & preferences.Display.TextFont, vbInformation, "TextFont Example"
    ' Reset TextFont to its original value
    preferences.Display.TextFont = currTextFont
    MsgBox "The TextFont value is reset to " & preferences.Display.TextFont, vbInformation, "TextFont Example"
(defun c:Example_TextFont()
    ;; TextFont. It then changes the value, and finally
    ;; Retrieve the current TextFont value
    (setq currTextFont (vla-get-TextFont (vla-get-Display preferences)))
    (alert (strcat "The current value for TextFont is " currTextFont))
    ;; Change the value for TextFont
    (vla-put-TextFont (vla-get-Display preferences) "TestTextFont")
    (alert (strcat "The new value for TextFont is " (vla-get-TextFont (vla-get-Display preferences))))
    ;; Reset TextFont to its original value
    (vla-put-TextFont (vla-get-Display preferences) currTextFont)
    (alert (strcat "The TextFont value is reset to " (vla-get-TextFont (vla-get-Display preferences))))
GMT+8, 2026-10-27 04:49
