TempXRefPath 属性 (ActiveX)
指定外部引用文件的位置。 支持的平台:仅限 Windows 属性值只读:不 类型:字符串 用于搜索外部引用文件的目录的驱动器和路径。 言论如果在属性上选择需求加载,则此位置将用于外部参照的副本。acEnableWithCopyXRefDemandLoad 例子VBA: Sub Example_TempXRefPath()
' TempXRefPath. It then changes the value, and finally
Dim currTempXRefPath As String
Dim newTempXRefPath As String
Set preferences = ThisDrawing.Application.preferences
' Retrieve the current TempXRefPath value
currTempXRefPath = preferences.Files.TempXrefPath
MsgBox "The current value for TempXRefPath is " & currTempXRefPath, vbInformation, "TempXRefPath Example"
' Change the value for TempXRefPath
newTempXRefPath = "TestTempXRefPath"
preferences.Files.TempXrefPath = newTempXRefPath
MsgBox "The new value for TempXRefPath is " & newTempXRefPath, vbInformation, "TempXRefPath Example"
' Reset TempXRefPath to its original value
preferences.Files.TempXrefPath = currTempXRefPath
MsgBox "The TempXRefPath value is reset to " & currTempXRefPath, vbInformation, "TempXRefPath Example"
可视化 LISP: (vl-load-com)
(defun c:Example_TempXRefPath()
;; TempXRefPath. It then changes the value, and finally
;; Retrieve the current TempXRefPath value
(setq currTempXRefPath (vla-get-TempXrefPath (vla-get-Files preferences)))
(alert (strcat "The current value for TempXRefPath is " currTempXRefPath))
;; Change the value for TempXRefPath
(setq newTempXRefPath "TestTempXRefPath")
(vla-put-TempXrefPath (vla-get-Files preferences) newTempXRefPath)
(alert (strcat "The new value for TempXRefPath is " newTempXRefPath))
;; Reset TempXRefPath to its original value
(vla-put-TempXrefPath (vla-get-Files preferences) currTempXRefPath)
(alert (strcat "The TempXRefPath value is reset to " currTempXRefPath))
GMT+8, 2026-10-27 05:43
