TemplateDWGPath 属性 (ActiveX)
指定启动向导使用的模板文件的路径。 支持的平台:仅限 Windows 属性值只读:不 类型:字符串 模板文件的驱动器和路径。 言论没有其他评论。 例子VBA: Sub Example_TemplateDWGPath()
' TemplateDWGPath. It then changes the value, and finally
Dim currTemplateDWGPath As String
Dim newTemplateDWGPath As String
Set preferences = ThisDrawing.Application.preferences
' Retrieve the current TemplateDWGPath value
currTemplateDWGPath = preferences.Files.TemplateDwgPath
MsgBox "The current value for TemplateDWGPath is " & currTemplateDWGPath, vbInformation, "TemplateDWGPath Example"
' Change the value for TemplateDWGPath
newTemplateDWGPath = "TestTemplateDWGPath"
preferences.Files.TemplateDwgPath = newTemplateDWGPath
MsgBox "The new value for TemplateDWGPath is " & newTemplateDWGPath, vbInformation, "TemplateDWGPath Example"
' Reset TemplateDWGPath to its original value
preferences.Files.TemplateDwgPath = currTemplateDWGPath
MsgBox "The TemplateDWGPath value is reset to " & currTemplateDWGPath, vbInformation, "TemplateDWGPath Example"
可视化 LISP: (vl-load-com)
(defun c:Example_TemplateDwgPath()
;; TemplateDwgPath. It then changes the value, and finally
;; Retrieve the current TemplateDWGPath value
(setq currTemplateDWGPath (vla-get-TemplateDwgPath (vla-get-Files preferences)))
(alert (strcat "The current value for TemplateDwgPath is " currTemplateDWGPath))
;; Change the value for TemplateDWGPath
(setq newTemplateDWGPath "TestTemplateDWGPath")
(vla-put-TemplateDwgPath (vla-get-Files preferences) newTemplateDWGPath)
(alert (strcat "The new value for TemplateDwgPath is " newTemplateDWGPath))
;; Reset TemplateDWGPath to its original value
(vla-put-TemplateDwgPath (vla-get-Files preferences) currTemplateDWGPath)
(alert (strcat "The TemplateDwgPath value is reset to " currTemplateDWGPath))
GMT+8, 2026-10-28 04:51
