TempFilePath 属性 (ActiveX)
2024-5-18 16:55| 发布者: admin| 查看: 1067| 评论: 0|原作者: admin|来自: AutoCAD
指定 AutoCAD 用于存储临时文件的目录。
object.TempFilePath
类型:PreferencesFiles
此属性应用于的对象。
只读:不
类型:字符串
用于临时文件的目录的驱动器和路径。
Sub Example_TempFilePath()
    ' TempFilePath. It then changes the value, and finally
    Dim currTempFilePath As String
    Dim newTempFilePath As String
    Set preferences = ThisDrawing.Application.preferences
    ' Retrieve the current TempFilePath value
    currTempFilePath = preferences.Files.TempFilePath
    MsgBox "The current value for TempFilePath is " & currTempFilePath, vbInformation, "TempFilePath Example"
    ' Change the value for TempFilePath
    newTempFilePath = "C:\AutoCAD\"
    preferences.Files.TempFilePath = newTempFilePath
    MsgBox "The new value for TempFilePath is " & newTempFilePath, vbInformation, "TempFilePath Example"
    ' Reset TempFilePath to its original value
    preferences.Files.TempFilePath = currTempFilePath
    MsgBox "The TempFilePath value is reset to " & currTempFilePath, vbInformation, "TempFilePath Example"
(defun c:Example_TempFilePath()
    ;; TempFilePath. It then changes the value, and finally
    ;; Retrieve the current TempFilePath value
    (setq currTempFilePath (vla-get-TempFilePath (vla-get-Files preferences)))
    (alert (strcat "The current value for TempFilePath is " currTempFilePath))
    ;; Change the value for TempFilePath
    (setq newTempFilePath "C:\\AutoCAD\\")
    (vla-put-TempFilePath (vla-get-Files preferences) newTempFilePath)
    (alert (strcat "The new value for TempFilePath is " newTempFilePath))
    ;; Reset TempFilePath to its original value
    (vla-put-TempFilePath (vla-get-Files preferences) currTempFilePath)
    (alert (strcat "The TempFilePath value is reset to " currTempFilePath))
GMT+8, 2026-11-3 17:43
