TabOrder 属性 (ActiveX)
指定布局的 Tab 键顺序。 支持的平台:仅限 Windows 属性值只读:不 类型:长 布局的 Tab 键顺序。 言论此属性控制布局在选项卡控件中的显示顺序。在数据库中的所有布局中,Tab 键顺序应该是唯一的和连续的。 模型空间选项卡的 Tab 键顺序必须为零 (0)。纸张空间选项卡的 Tab 键顺序必须为 1 或更大。 例子VBA: Sub Example_TabOrder()
' This example creates two new Layouts, sets the TabOrder of the Layouts to be
' in alphabetic order, and displays a list of Layouts in the order they appear
' in the tabs.
Dim Layout1 As ACADLayout, Layout2 As ACADLayout
Dim SortLayoutRight As ACADLayout, SortLayoutLeft As ACADLayout
Dim SortIt As New Collection
Dim TabCount As Long, SortCount As Long, TabOrder As Long
Dim TabName As String, SortText As String, msg As String
Dim tempLayout As ACADLayout
Dim AddedTab As Boolean
' Create new Layouts
On Error Resume Next
Set Layout1 = ThisDrawing.Layouts.Add("Z VIEW")
Set Layout2 = ThisDrawing.Layouts.Add("A VIEW")
On Error GoTo 0
' Alphabetize internally
For TabCount = 0 To (ThisDrawing.Layouts.count - 1)
AddedTab = False
TabName = ThisDrawing.Layouts(TabCount).name
If TabName = "Model" Then GoTo SKIP ' Skip modelspace
If SortIt.count = 0 Then
SortIt.Add TabName ' Add to beginning of list
Else
For SortCount = 1 To SortIt.count ' Add to list by string
SortText = SortIt(SortCount)
If StrComp(TabName, SortText, vbTextCompare) = -1 Then
If SortCount = 1 Then
SortIt.Add TabName ' Add as first item
Else
SortIt.Add TabName, , SortCount ' Add as previous item
End If
AddedTab = True
Exit For
End If
Next
If Not (AddedTab) Then SortIt.Add TabName, , , SortIt.count ' Add if we haven't yet
End If
SKIP:
Next
' Write new ACAD tab order
Set tempLayout = ThisDrawing.Layouts(SortIt(SortCount))
tempLayout.TabOrder = SortCount
Next
' Read and display New Tab Order
msg = "The tab order is now set to: " & vbCrLf & vbCrLf
If TabName = "Model" Then GoTo SKIP2 ' Don't show modelspace
TabOrder = ThisDrawing.Layouts(TabCount).TabOrder
msg = msg & "(" & TabOrder & ")" & vbTab & TabName & vbCrLf
SKIP2:
Next
MsgBox msg, vbInformation
可视化 LISP: (vl-load-com)
(defun c:Example_TabOrder()
;; This example creates two new Layouts, sets the TabOrder of the Layouts to be
;; in alphabetic order, and displays a list of Layouts in the order they appear
;; in the tabs.
;; Create new Layouts
(setq Layout1 (vla-Add (vla-get-Layouts doc) "Z VIEW"))
(setq Layout2 (vla-Add (vla-get-Layouts doc) "A VIEW"))
(setq SortIt (list)
TabCount 0)
;; Alphabetize internally
(while (>= (1- (vla-get-Count (vla-get-Layouts doc))) TabCount)
(setq AddedTab :vlax-false)
(setq TabName (vla-get-Name (vla-Item (vla-get-Layouts doc) TabCount)))
(if (/= (strcase TabName) "MODEL") ;; Skip modelspace
(progn
(setq SortIt (append SortIt (list TabName))) ;; Add to beginning of list
(setq TabCount (1+ TabCount))
;; Sort layout names
(setq SortIt (acad_strlsort SortIt)
SortCount 1)
;; Update tab order
(foreach name SortIt
(progn
(setq tempLayout (vla-Item (vla-get-Layouts doc) name))
(vla-put-TabOrder tempLayout SortCount)
(setq SortCount (1+ SortCount))
;; Read and display New Tab Order
(setq msg "The tab order is now set to: \n"
TabCount 0)
(progn
(setq TabOrder (vla-get-TabOrder (vla-Item (vla-get-Layouts doc) TabCount)))
(setq msg (strcat msg "(" (itoa TabOrder) ") " TabName "\n"))
(alert msg)
GMT+8, 2026-10-27 01:21
