TablesReadOnly 属性 (ActiveX)
确定是否以只读模式打开数据库表。 支持的平台:仅限 Windows 属性值只读:不 类型:布尔
言论此属性的初始值为 。False 例子VBA: Sub Example_TablesReadOnly()
' This example reads and modifies the preference value that controls
' whether to open database tables in read-only mode.
' When finished, this example resets the preference value back to
' its original value.
Dim ACADPref As AcadPreferencesSystem
' Get the system preferences object
Set ACADPref = ThisDrawing.Application.Preferences.System
originalValue = ACADPref.TablesReadOnly
MsgBox "The TablesReadOnly preference is set to: " & originalValue
' Modify the TablesReadOnly preference by toggling the value
ACADPref.TablesReadOnly = Not (ACADPref.TablesReadOnly)
newValue = ACADPref.TablesReadOnly
MsgBox "The TablesReadOnly preference has been set to: " & newValue
' this preference in effect
ACADPref.TablesReadOnly = originalValue
MsgBox "The TablesReadOnly preference was reset back to: " & originalValue
可视化 LISP: (vl-load-com)
(defun c:Example_TablesReadOnly()
;; This example reads and modifies the preference value that controls
;; whether to open database tables in read-only mode.
;; When finished, this example resets the preference value back to
;; its original value.
(setq originalValue (vla-get-TablesReadOnly (vla-get-System preferences)))
(alert (strcat "The TablesReadOnly preference is set to: " (if (= originalValue :vlax-true) "True" "False")))
;; Modify the TablesReadOnly preference by toggling the value
(vla-put-TablesReadOnly (vla-get-System preferences) (if (= originalValue :vlax-true) :vlax-false :vlax-true))
(alert (strcat "The TablesReadOnly preference has been set to: " (if (= (vla-get-TablesReadOnly (vla-get-System preferences)) :vlax-true) "True" "False")))
;; this preference in effect
(vla-put-TablesReadOnly (vla-get-System preferences) originalValue)
(alert (strcat "The TablesReadOnly preference was reset back to: " (if (= (vla-get-TablesReadOnly (vla-get-System preferences)) :vlax-true) "True" "False")))
GMT+8, 2026-11-15 11:42
