TableBreakHeight 属性 (ActiveX)
设置初始工作台零件和任何其他未设置手动高度的工作台零件的断裂高度。 支持的平台:仅限 Windows 属性值只读:不 类型:双 断裂高度的值。 言论没有其他评论。 例子VBA: Sub Example_BreakHeight()
' This example creates a table object and then breaks it into
' two tables.
' Create a new table objetc in model space
Dim pt(2) As Double
Dim modelSpace As AcadModelSpace
Set modelSpace = ThisDrawing.modelSpace
Dim table As AcadTable
Set table = modelSpace.AddTable(pt, 5, 5, 10, 30)
table.EnableBreak = True
table.BreakSpacing = 3.5
table.TableBreakHeight = 35#
table.AllowManualHeights = True
table.SetBreakHeight 0, 20#
table.SetBreakHeight 1, 35#
ZoomExtents
可视化 LISP: (vl-load-com)
(defun c:Example_BreakHeight()
;; This example creates a table object and then breaks it into
;; two tables.
;; Create a new table objetc in model space
(setq pt (vlax-3d-point 0 0 0))
(setq table (vla-Addtable modelSpace pt 5 5 10 30))
(vla-put-EnableBreak table :vlax-true)
(vla-put-BreakSpacing table 3.5)
(vla-put-TableBreakHeight table 35.0)
(vla-put-AllowManualHeights table :vlax-true)
(vla-SetBreakHeight table 0 20.0)
(vla-SetBreakHeight table 1 35.0)
(vla-ZoomExtents acadObj)
GMT+8, 2026-10-28 06:07
