SuppressZeroInches 属性 (ActiveX)
指定在尺寸值中隐含零英寸测量值。 支持的平台:仅限 Windows 签名VBA: object.SuppressZeroInches
属性值只读:不 类型:布尔
言论此属性的初始值为 。False 注意:此属性将覆盖给定维度的 DIMZIN 系统变量的值。
例子VBA: Sub Example_SuppressZeroInches()
' uses SuppressZeroInches to suppress or view the display of
' zero inches in the dimension display
Dim dimObj As AcadDimAligned
' Define the dimension
point1(0) = 0: point1(1) = 5: point1(2) = 0
point2(0) = 12: point2(1) = 5: point2(2) = 0
' Set the dimension display to a style that works with SuppressZeroInches
dimObj.UnitsFormat = acDimLArchitectural
Toggle:
Select Case MsgBox("Press OK to suppress or view the display of zero inches in the dimension", vbOKCancel)
Case vbOK
' Toggle the display of zero inches for the dimension value
dimObj.SuppressZeroInches = Not (dimObj.SuppressZeroInches)
Case vbCancel
Exit Sub
End Select
GoTo Toggle
可视化 LISP: (vl-load-com)
(defun c:Example_SuppressZeroInches()
;; uses SuppressZeroInches to suppress or view the display of
;; zero inches in the dimension display
;; Define the dimension
(setq point1 (vlax-3d-point 0 5 0)
point2 (vlax-3d-point 12 5 0)
(vla-ZoomAll acadObj)
;; Set the dimension display to a style that works with SuppressZeroInches
(vla-put-UnitsFormat dimObj acDimLArchitectural)
;; Toggle the display of zero inches for the dimension value
(vla-put-SuppressZeroInches dimObj (if (= (vla-get-SuppressZeroInches dimObj) :vlax-true) :vlax-false :vlax-true))
(alert "Suppression of zero inches toggled.")
;; Toggle the display of zero inches for the dimension value back to previous state
(alert "Suppression of zero inches toggled back.")
GMT+8, 2026-10-27 04:47
