SuppressLeadingZeros 属性 (ActiveX)
2024-5-18 16:55| 发布者: admin| 查看: 910| 评论: 0|原作者: admin|来自: AutoCAD
指定禁止显示维度值中的前导零。
object.SuppressLeadingZeros
类型:Dim3PointAngular、DimAligned、DimAngular、DimArcLength、DimDiametric、Dimension、DimOrdinate、DimRadial、DimRadialLarge、DimRotated
此属性应用于的对象。
只读:不
类型:布尔
  • True:禁止显示十进制尺寸中的前导零。例如,0.5000 变为 .5000。
  • False:不要禁止十进制尺寸中的前导零。
此属性的初始值为 。False
注意:此值将覆盖 DIMZIN 系统变量的值。
Sub Example_SuppressLeadingZeros()
   ' uses the SuppressLeadingZeros property to toggle the display of leading zeros
   ' in the dimension display
    Dim dimObj As AcadDimAligned
    ' Define the dimension
    point2(0) = 5.01: point2(1) = 5: point2(2) = 0
Toggle:
    Select Case MsgBox("Press OK to toggle the display of leading zeros in the dimension", vbOKCancel)
        Case vbOK
            ' Toggle the display of leading zeros for the dimension value
            dimObj.SuppressLeadingZeros = Not (dimObj.SuppressLeadingZeros)
        Case vbCancel
            Exit Sub
    End Select
    GoTo Toggle
(defun c:Example_SuppressLeadingZeros()
    ;; uses the SuppressLeadingZeros property to toggle the display of leading zeros
    ;; in the dimension display
    ;; Define the dimension
          point2 (vlax-3d-point 5.01 5 0)
    (vla-ZoomAll acadObj)
    ;; Toggle the display of leading zeros for the dimension value
    (vla-put-SuppressLeadingZeros dimObj (if (= (vla-get-SuppressLeadingZeros dimObj) :vlax-true) :vlax-false :vlax-true))
    (alert "Suppression of leading zeros toggled.")
    ;; Toggle the display of leading zeros for the dimension value back to previous state
    (alert "Suppression of leading zeros toggled back.")
GMT+8, 2026-10-28 04:48
