SupportPath 属性 (ActiveX)
2024-5-18 16:55| 发布者: admin| 查看: 963| 评论: 0|原作者: admin|来自: AutoCAD
指定 AutoCAD 搜索支持文件的目录。
object.SupportPath
类型:PreferencesFiles
此属性应用于的对象。
只读:不
类型:字符串
支持文件所在的目录。指定支持、字体、帮助和奖励文件的驱动器号和路径。
使用分号 (;) 分隔多个目录;但是,不要以分号结束字符串。
Sub Example_SupportPath()
    ' SupportPath. It then changes the value, and finally
    Dim currSupportPath As String
    Dim newSupportPath As String
    Set preferences = ThisDrawing.Application.preferences
    ' Retrieve the current SupportPath value
    currSupportPath = preferences.Files.SupportPath
    MsgBox "The current value for SupportPath is " & currSupportPath, vbInformation, "SupportPath Example"
    ' Change the value for SupportPath
    newSupportPath = "TestSupportPath"
    preferences.Files.SupportPath = newSupportPath
    MsgBox "The new value for SupportPath is " & newSupportPath, vbInformation, "SupportPath Example"
    ' Reset SupportPath to its original value
    preferences.Files.SupportPath = currSupportPath
    MsgBox "The SupportPath value is reset to " & currSupportPath, vbInformation, "SupportPath Example"
(defun c:Example_SupportPath()
    ;; SupportPath. It then changes the value, and finally
    ;; Retrieve the current SupportPath value
    (setq currSupportPath (vla-get-SupportPath (vla-get-Files preferences)))
    (alert (strcat "The current value for SupportPath is " currSupportPath))
    ;; Change the value for SupportPath
    (setq newSupportPath "TestSupportPath")
    (vla-put-SupportPath (vla-get-Files preferences) newSupportPath)
    (alert (strcat "The new value for SupportPath is " newSupportPath))
    ;; Reset SupportPath to its original value
    (vla-put-SupportPath (vla-get-Files preferences) currSupportPath)
    (alert (strcat "The SupportPath value is reset to " currSupportPath))
GMT+8, 2026-10-28 03:06
