SubMenu 属性 (ActiveX)
获取与子菜单关联的弹出菜单。 支持的平台:仅限 Windows 言论如果弹出菜单项不是子菜单,则此属性将返回错误。 例子VBA: Sub Example_SubMenu()
' This example finds the menu used as the sub menu for the
' "Additional Resources" menu item in the Help menu.
Dim acadMenuGroup As acadMenuGroup
Set acadMenuGroup = ThisDrawing.Application.MenuGroups.Item("ACAD")
Dim helpMenu As AcadPopupMenu
Set helpMenu = acadMenuGroup.Menus.Item("&Help")
Dim menuItem As AcadPopupMenuItem
Set menuItem = helpMenu.Item(4)
Dim subMenu As AcadPopupMenu
Set subMenu = menuItem.subMenu
MsgBox "The name of the submenu is " & subMenu.TagString
可视化 LISP: (vl-load-com)
(defun c:Example_SubMenu()
;; This example finds the menu used as the sub menu for the
;; "Additional Resources" menu item in the Help menu.
(setq acadMenuGroup (vla-Item (vla-get-MenuGroups acadObj) "ACAD"))
(setq helpMenu (vla-Item (vla-get-Menus acadMenuGroup) "&Help"))
(setq menuItem (vla-Item helpMenu 4))
(setq subMenu (vla-get-SubMenu menuItem))
(alert (strcat "The name of the submenu is " (vla-get-TagString subMenu)))
GMT+8, 2026-10-27 04:49
