StyleName 属性 (ActiveX)
指定用于对象的样式的名称。 支持的平台:仅限 Windows 签名VBA: object.StyleName 属性值只读:不;只读对象除外MLine 类型:字符串 默认值等于当前样式。 言论使用对象更改给定文本样式的属性。使用对象更改给定维度样式的属性。TextStyleDimStyle 给定的名称必须已在图形中定义。 注意:对于尺寸,此属性的值存储在 DIMSTYLE 系统变量中。
例子VBA: Sub Example_StyleName()
' This example creates an aligned dimension and then changes the
' StyleName property for that dimension.
Dim dimObj As AcadDimAligned
Dim point1(0 To 2) As Double
Dim point2(0 To 2) As Double
Dim currStyleName As String
' Define the dimension
point1(0) = 5#: point1(1) = 3#: point1(2) = 0#
point2(0) = 10#: point2(1) = 3#: point2(2) = 0#
location(0) = 7.5: location(1) = 5#: location(2) = 0#
ZoomAll
currStyleName = dimObj.styleName
MsgBox "The initial StyleName for the dimension is " & dimObj.styleName, vbInformation, "TextString Example"
' Create a new dimension style
ThisDrawing.DimStyles.Add ("NewDimensionStyle")
' Change the text string for the dimension
dimObj.styleName = "NewDimensionStyle"
dimObj.Update
MsgBox "The new StyleName for the dimension is " & dimObj.styleName, vbInformation, "TextString Example"
' Reset the text string for the dimension
dimObj.styleName = currStyleName
dimObj.Update
MsgBox "The StyleName for the dimension has been reset to " & dimObj.styleName, vbInformation, "TextString Example"
可视化 LISP: (vl-load-com)
(defun c:Example_StyleName()
;; This example creates an aligned dimension and then changes the
;; StyleName property for that dimension.
;; Define the dimension
(setq point1 (vlax-3d-point 5 3 0)
point2 (vlax-3d-point 10 3 0)
location (vlax-3d-point 7.5 5 0))
(vla-ZoomAll acadObj)
(setq currStyleName (vla-get-StyleName dimObj))
(alert (strcat "The initial StyleName for the dimension is " currStyleName))
;; Create a new dimension style
(vla-Add (vla-get-DimStyles doc) "NewDimensionStyle")
;; Change the text string for the dimension
(vla-put-StyleName dimObj "NewDimensionStyle")
(vla-Update dimObj)
(alert (strcat "The new StyleName for the dimension is " (vla-get-StyleName dimObj)))
;; Reset the text string for the dimension
(vla-put-StyleName dimObj currStyleName)
(vla-Update dimObj)
(alert (strcat "The StyleName for the dimension has been reset to " (vla-get-StyleName dimObj)))
GMT+8, 2026-10-28 06:06
