StoreSQLIndex 属性 (ActiveX)
确定 SQL 索引是否存储在图形中。 支持的平台:仅限 Windows 属性值只读:不 类型:布尔
言论此属性的初始值为 。True 例子VBA: Sub Example_StoreSQLIndex()
' This example reads and modifies the preference value that controls
' whether the SQL index is stored in the drawing.
' When finished, this example resets the preference value back to
' its original value.
Dim ACADPref As AcadPreferencesSystem
' Get the system preferences object
Set ACADPref = ThisDrawing.Application.preferences.System
originalValue = ACADPref.StoreSQLIndex
MsgBox "The StoreSQLIndex preference is set to: " & originalValue
' Modify the StoreSQLIndex preference by toggling the value
ACADPref.StoreSQLIndex = Not (ACADPref.StoreSQLIndex)
newValue = ACADPref.StoreSQLIndex
MsgBox "The StoreSQLIndex preference has been set to: " & newValue
' this preference in effect
ACADPref.StoreSQLIndex = originalValue
MsgBox "The StoreSQLIndex preference was reset back to: " & originalValue
可视化 LISP: (vl-load-com)
(defun c:Example_StoreSQLIndex()
;; This example reads and modifies the preference value that controls
;; whether the SQL index is stored in the drawing.
;; When finished, this example resets the preference value back to
;; its original value.
(setq originalValue (vla-get-StoreSQLIndex (vla-get-System preferences)))
(alert (strcat "The StoreSQLIndex preference is set to: " (if (= originalValue :vlax-true) "True" "False")))
;; Modify the StoreSQLIndex preference by toggling the value
(vla-put-StoreSQLIndex (vla-get-System preferences) (if (= originalValue :vlax-true) :vlax-false :vlax-true))
(alert (strcat "The StoreSQLIndex preference has been set to: " (if (= (vla-get-StoreSQLIndex (vla-get-System preferences)) :vlax-true) "True" "False")))
;; this preference in effect
(vla-put-StoreSQLIndex (vla-get-System preferences) originalValue)
(alert (strcat "The StoreSQLIndex preference was reset back to: " (if (= (vla-get-StoreSQLIndex (vla-get-System preferences)) :vlax-true) "True" "False")))
GMT+8, 2026-10-27 04:47
