StandardScale2 属性 (ActiveX)
指定视口的标准比例。 支持的平台:仅限 Windows 属性值只读:不 类型:长 视口的标准比例值。 言论没有其他评论。 例子VBA: Sub Example_StandardScale()
' This example will access the active layout for the current drawing
' and list the standard scale for that Layout.
' It then changes the standard scale for the layout, and finally
' resets the scale back to its original value.
Dim Layout As ACADLayout
Dim currScale As Integer
' Get the activeLayout
Set Layout = ThisDrawing.ActiveLayout
' Find the current standard scale
currScale = Layout.StandardScale
MsgBox "The current standard scale is : " & Layout.StandardScale
' Change the standard scale to 100:1
Layout.StandardScale = ac100_1
MsgBox "The new standard scale is : " & Layout.StandardScale
' Reset the original standard scale
Layout.StandardScale = currScale
可视化 LISP: (vl-load-com)
(defun c:Example_StandardScale()
;; This example will access the active layout for the current drawing
;; and list the standard scale for that Layout.
;; It then changes the standard scale for the layout, and finally
;; resets the scale back to its original value.
;; Get the activeLayout
(setq Layout (vla-get-ActiveLayout doc))
;; Find the current standard scale
(setq currScale (vla-get-StandardScale Layout))
(alert (strcat "The current standard scale is : " (itoa currScale)))
;; Change the standard scale to 100:1
(vla-put-StandardScale Layout ac100_1)
(alert (strcat "The new standard scale is : " (itoa (vla-get-StandardScale Layout))))
;; Reset the original standard scale
(vla-put-StandardScale Layout currScale)
GMT+8, 2026-10-27 09:50
