SolidFill 属性 (ActiveX)
指定是否填充迹线、实体、所有填充线(包括实体填充)和宽折线。 支持的平台:仅限 Windows 属性值只读:不 类型:布尔
言论此属性的初始值为 。True 注意:此属性的值存储在 FILLMODE 系统变量中。
例子VBA: Sub Example_SolidFill()
' This example reads and modifies the preference value that controls
' whether multilines, traces, solids, all hatches (including solid-fill)
' and wide polylines are filled in.
' When finished, this example resets the preference value back to
' its original value.
Dim ACADPref As AcadDatabasePreferences
' Get the user preferences object
Set ACADPref = ThisDrawing.Preferences
originalValue = ACADPref.SolidFill
MsgBox "The SolidFill preference is set to: " & originalValue
' Modify the SolidFill preference by toggling the value
ACADPref.SolidFill = Not (ACADPref.SolidFill)
newValue = ACADPref.SolidFill
MsgBox "The SolidFill preference has been set to: " & newValue
' this preference in effect
ACADPref.SolidFill = originalValue
MsgBox "The SolidFill preference was reset back to: " & originalValue
可视化 LISP: (vl-load-com)
(defun c:Example_SolidFill()
;; This example reads and modifies the preference value that controls
;; whether multilines, traces, solids, all hatches (including solid-fill)
;; and wide polylines are filled in.
;; When finished, this example resets the preference value back to
;; its original value.
(setq preferences (vla-get-Preferences doc))
(setq originalValue (vla-get-SolidFill preferences))
(alert (strcat "The SolidFill preference is set to: " (if (= originalValue :vlax-true) "True" "False")))
;; Modify the SolidFill preference by toggling the value
(vla-put-SolidFill preferences (if (= originalValue :vlax-true) :vlax-false :vlax-true))
(setq newValue (vla-get-SolidFill preferences))
(alert (strcat "The SolidFill preference has been set to: " (if (= newValue :vlax-true) "True" "False")))
;; this preference in effect
(vla-put-SolidFill preferences originalValue)
(alert (strcat "The SolidFill preference was reset back to: " (if (= originalValue :vlax-true) "True" "False")))
GMT+8, 2026-10-28 04:49
