SingleDocumentMode 属性 (ActiveX)
确定AutoCAD是在单文档模式下运行还是在多文档模式下运行。 支持的平台:仅限 Windows 属性值只读:不 类型:布尔
言论此属性的初始值为 。False 此属性可帮助第三方开发人员更新应用程序,以便在 AutoCAD 多重图形模式下顺利工作。在AutoCAD的未来版本中,它可能会过时。 注意:此属性的值存储在 SDI 系统变量中。
例子VBA: Sub Example_SingleDocumentMode()
' This example reads and modifies the preference value that controls
' whether AutoCAD runs in single- or multiple-document mode.
' When finished, this example resets the preference value back to
' its original value.
Dim ACADPref As AcadPreferencesSystem
' Get the system preferences object
Set ACADPref = ThisDrawing.Application.Preferences.System
originalValue = ACADPref.SingleDocumentMode
MsgBox "The SingleDocumentMode preference is set to: " & originalValue
' Modify the SingleDocumentMode preference by toggling the value
ACADPref.SingleDocumentMode = Not (ACADPref.SingleDocumentMode)
newValue = ACADPref.SingleDocumentMode
MsgBox "The SingleDocumentMode preference has been set to: " & newValue
' this preference in effect
ACADPref.SingleDocumentMode = originalValue
MsgBox "The SingleDocumentMode preference was reset back to: " & originalValue
可视化 LISP: (vl-load-com)
(defun c:Example_SingleDocumentMode()
;; This example reads the preference value that lists
;; whether AutoCAD is running in single- or multiple-document mode.
;; Read the current value
(setq currValue (vla-get-SingleDocumentMode (vla-get-System preferences)))
(alert (strcat "The SingleDocumentMode preference is set to: " (if (= currValue :vlax-true) "True" "False")))
GMT+8, 2026-10-27 01:22
