ShowWarningMessages 属性 (ActiveX)
重置所有具有“不再显示此警告”复选框的对话框,以便它们再次显示。 支持的平台:仅限 Windows 属性值只读:不 类型:布尔
言论此属性的初始值为 。False 例子VBA: Sub Example_ShowWarningMessages()
' This example reads and modifies the preference value that
' resets all dialog boxes that have the
' "Don't Display This Warning Again" check box so they display again.
' When finished, this example resets the preference value back to
' its original value.
Dim ACADPref As AcadPreferencesSystem
' Get the system preferences object
Set ACADPref = ThisDrawing.Application.Preferences.System
originalValue = ACADPref.ShowWarningMessages
MsgBox "The ShowWarningMessages preference is set to: " & originalValue
' Modify the ShowWarningMessages preference by toggling the value
ACADPref.ShowWarningMessages = Not (ACADPref.ShowWarningMessages)
newValue = ACADPref.ShowWarningMessages
MsgBox "The ShowWarningMessages preference has been set to: " & newValue
' this preference in effect
ACADPref.ShowWarningMessages = originalValue
MsgBox "The ShowWarningMessages preference was reset back to: " & originalValue
可视化 LISP: (vl-load-com)
(defun c:Example_ShowWarningMessages()
;; This example reads and modifies the preference value that
;; resets all dialog boxes that have the
;; "Don't Display This Warning Again" check box so they display again.
;; When finished, this example resets the preference value back to
;; its original value.
(setq originalValue (vla-get-ShowWarningMessages (vla-get-System preferences)))
(alert (strcat "The ShowWarningMessages preference is set to: " (if (= originalValue :vlax-true) "True" "False")))
;; Modify the ShowWarningMessages preference by toggling the value
(vla-put-ShowWarningMessages (vla-get-System preferences) (if (= originalValue :vlax-true) :vlax-false :vlax-true))
(alert (strcat "The ShowWarningMessages preference has been set to: " (if (= (vla-get-ShowWarningMessages (vla-get-System preferences)) :vlax-true) "True" "False")))
;; this preference in effect
(vla-put-ShowWarningMessages (vla-get-System preferences) originalValue)
(alert (strcat "The ShowWarningMessages preference was reset back to: " (if (= (vla-get-ShowWarningMessages (vla-get-System preferences)) :vlax-true) "True" "False")))
GMT+8, 2026-10-27 04:30
