ShowPlotStyles 属性 (ActiveX)
指定是否在图形中显示打印样式和打印样式名称。 支持的平台:仅限 Windows 属性值只读:不 类型:布尔
言论该特性等同于 AutoCAD 中的“显示打印样式”选项。ShowPlotStyles 例子VBA: Sub Example_ShowPlotStyles()
' This example reads and modifies the ShowPlotStyles
' value, and then regenerates all viewports.
Dim ACADLayout As ACADLayout
Dim originalValue As Boolean
' Get the layout object
Set ACADLayout = ThisDrawing.ActiveLayout
originalValue = ACADLayout.ShowPlotStyles
MsgBox "The ShowPlotStyles value is set to: " & originalValue
' Modify the ShowPlotStyles preference by changing the value
ACADLayout.ShowPlotStyles = Not ACADLayout.ShowPlotStyles
MsgBox "The ShowPlotStyles value has been set to: " & ACADLayout.ShowPlotStyles
' Regenerate viewports
可视化 LISP: (vl-load-com)
(defun c:Example_ShowPlotStyles()
;; This example reads and modifies the ShowPlotStyles
;; value, and then regenerates all viewports.
;; Get the layout object
(setq ACADLayout (vla-get-ActiveLayout doc))
(setq originalValue (vla-get-ShowPlotStyles ACADLayout))
(alert (strcat "The ShowPlotStyles value is set to: " (if (= originalValue :vlax-true) "True" "False")))
;; Modify the ShowPlotStyles preference by changing the value
(vla-put-ShowPlotStyles ACADLayout (if (= originalValue :vlax-true) :vlax-false :vlax-true))
(alert (strcat "The ShowPlotStyles value has been set to: " (if (= (vla-get-ShowPlotStyles ACADLayout) :vlax-true) "True" "False")))
;; Regenerate viewports
GMT+8, 2026-10-27 05:42
