ShadePlot 属性 (ActiveX)
2024-5-18 16:55| 发布者: admin| 查看: 854| 评论: 0|原作者: admin|来自: AutoCAD
指定视口的着色视口打印模式。
object.ShadePlot
类型: PViewport
此属性应用于的对象。
只读:不
类型:枚举AcShadePlot
  • acShadePlotAsDisplayed:模型空间视图的绘图方式与显示方式相同。
  • acShadePlotHidden:删除隐藏线的模型空间视图图,无论显示方式如何。
  • acShadePlotRendered:模型空间视图绘图为渲染,而不考虑显示方式。
  • acShadePlotWireframe:模型空间视图以线框形式绘制,而不考虑显示方式。
Sub Example_ShadePlot()
    ' This example creates a paper space viewport,
    ' makes it active, and then sets it to plot as displayed.
    Dim newPViewport As AcadPViewport
    Dim height As Double
    Dim width As Double
    height = 30#
    width = 40#
    centerPoint(0) = 30#: centerPoint(1) = 30#: centerPoint(2) = 0#
    ' Create a paper space Viewport object
    ThisDrawing.ActiveSpace = acPaperSpace
    Set newPViewport = ThisDrawing.PaperSpace.AddPViewport(centerPoint, width, height)
    ZoomAll
    newPViewport.Display True
    ThisDrawing.MSpace = True
    ' Set the viewport to plot as displayed
    ThisDrawing.ActivePViewport = newPViewport
    newPViewport.ShadePlot = acShadePlotAsDisplayed
(defun c:Example_ShadePlot()
    ;; This example creates a paper space viewport,
    ;; makes it active, and then sets it to plot as displayed.
    (setq centerPoint (vlax-3d-point 30 30 0)
          width 40
          height 40)
    ;; Create a paper space Viewport object
    (vla-put-ActiveSpace doc acPaperSpace)
    (setq paperSpace (vla-get-PaperSpace doc))
    (setq newPViewport (vla-AddPViewport paperSpace centerPoint width height))
    (vla-ZoomAll acadObj)
    (vla-Display newPViewport :vlax-true)
    (vla-put-MSpace doc :vlax-true)
    ;; Set the viewport to plot as displayed
    (vla-put-ActivePViewport doc newPViewport)
    (vla-put-ShadePlot newPViewport acShadePlotAsDisplayed)
GMT+8, 2026-11-21 13:01
