Selection 属性 (ActiveX)
2024-5-18 16:55| 发布者: admin| 查看: 816| 评论: 0|原作者: admin|来自: AutoCAD
获取 PreferencesSelection 对象。
object.Selection
类型:首选项
此属性应用于的对象。
只读:是的
类型:首选项选择
获取对象。PreferencesSelection
该对象保存存储在注册表中的“选项”对话框的“选择”选项卡中的所有选项。与图形一起存储的所有选项都可以在对象上找到。PreferencesSelectionDatabasePreferences
Sub Example_Selection()
    ' This example obtains a reference to the Selection Preferences object
    ' from the Application Preferences object, and reads one of the Selection
    ' preferences
    Dim ACADPref As AcadPreferencesSelection
    ' Obtain a reference to the Selection Preferences object
    Set ACADPref = ThisDrawing.Application.Preferences.Selection
    MsgBox "We now have access to the properties and methods of the Selection Preferences object!"
    MsgBox "The Selection preference GripSize is set to: " & ACADPref.GripSize
(defun c:Example_Selection()
    ;; This example obtains a reference to the Selection Preferences object
    ;; from the Application Preferences object, and reads one of the Selection
    ;; preferences
    (alert "We now have access to the properties and methods of the Selection Preferences object!")
    (alert (strcat "The Selection preference GripSize is set to: " (itoa (vla-get-GripSize (vla-get-Selection preferences)))))
GMT+8, 2026-10-27 04:53
