SCMTimeValue 属性 (ActiveX)
2024-5-18 16:55| 发布者: admin| 查看: 927| 评论: 0|原作者: admin|来自: AutoCAD
通过设置显示快捷菜单的长按持续时间来控制时间敏感的右键单击行为。
object.SCMTimeValue
类型:PreferencesUser
此属性应用于的对象。
只读:不
类型:长
介于 100 和 10,000 之间的数字(以毫秒为单位)。初始值为 250。
当该属性设置为 时,此属性会影响右键单击行为。SCMTimeModeTrue
注意:此属性的值存储在 SHORTCUTMENUDURATION 系统变量中。
Sub Example_SCMTimeValue()
    ' This example reads and modifies the SCMTimeValue property.
    ' Then the property is reset to its original value.
    Dim ACADPref As AcadPreferencesUser
    Dim originalValue As Integer, newValue As Integer
    ' Get the UserPreferences object and set the SCMTimeMode property to True
    Set ACADPref = ThisDrawing.Application.Preferences.User
    ACADPref.SCMTimeMode = True
    originalValue = ACADPref.SCMTimeValue
    MsgBox "The SCMTimeValue property is currently: " & originalValue
    newValue = 1000
    ACADPref.SCMTimeValue = newValue
    MsgBox "The SCMTimeValue property has been set to: " & ACADPref.SCMTimeValue
    ACADPref.SCMTimeValue = originalValue
    MsgBox "The SCMTimeValue property was reset back to: " & originalValue
(defun c:Example_SCMTimeValue()
    ;; This example reads and modifies the SCMTimeValue property.
    ;; Then the property is reset to its original value.
    ;; Get the UserPreferences object and set the SCMTimeMode property to True
    (vla-put-SCMTimeMode (vla-get-User preferences) :vlax-true)
    (setq originalValue (vla-get-SCMTimeValue (vla-get-User preferences)))
    (alert (strcat "The SCMTimeValue property is currently: " (itoa originalValue)))
    (setq newValue 1000)
    (vla-put-SCMTimeValue (vla-get-User preferences) newValue)
    (alert (strcat "The SCMTimeValue property has been set to: " (itoa (vla-get-SCMTimeValue (vla-get-User preferences)))))
    (vla-put-SCMTimeValue (vla-get-User preferences) originalValue)
    (alert (strcat "The SCMTimeValue property was reset back to: " (itoa originalValue)))
GMT+8, 2026-10-28 06:08
