SCMDefaultMode 属性 (ActiveX)
2024-5-18 16:55| 发布者: admin| 查看: 751| 评论: 0|原作者: admin|来自: AutoCAD
在“默认”模式下确定绘图区域中的右键单击功能,这意味着未选择任何对象,也未执行任何命令。
object.SCMDefaultMode
类型:PreferencesUser
此属性应用于的对象。
只读:不
类型:枚举AcDrawingAreaSCMDefault
  • acRepeatLastCommand:禁用默认快捷菜单。因此,当未选择任何对象且未执行任何命令时,在绘图区域中单击鼠标右键将发出 Enter,这将重复上次发出的命令。
  • acSCM:启用默认快捷菜单。
此属性的初始值为 。acSCM
仅当该属性设置为 时,才能设置此属性。ShortcutMenuDisplayTrue
注意:此属性的值存储在 SHORTCUTMENU 系统变量中。
Sub Example_SCMDefaultMode()
    ' This example reads and modifies the SCMDefaultMode
    ' preference value.
    ' When finished, this example resets the preference value back to
    ' its original value.
    Dim ACADPref As AcadPreferencesUser
    Dim originalValue As Integer, newValue As Integer
    ' Get the user preferences object
    Set ACADPref = ThisDrawing.Application.Preferences.User
    originalValue = ACADPref.SCMDefaultMode
    MsgBox "The SCMDefaultMode preference is set to: " & originalValue
    ' Modify the SCMDefaultMode preference by toggling the value
    ACADPref.SCMDefaultMode = acRepeatLastCommand
    MsgBox "The SCMDefaultMode preference has been set to: " & ACADPref.SCMDefaultMode
    ACADPref.SCMDefaultMode = originalValue
    MsgBox "The SCMDefaultMode preference was reset back to: " & originalValue
(defun c:Example_SCMDefaultMode()
    ;; This example reads and modifies the SCMDefaultMode
    ;; preference value.
    ;; When finished, this example resets the preference value back to
    ;; its original value.
    (setq originalValue (vla-get-SCMDefaultMode (vla-get-User preferences)))
    (alert (strcat "The SCMDefaultMode preference is set to: " (itoa originalValue)))
    ;; Modify the SCMDefaultMode preference by toggling the value
    (vla-put-SCMDefaultMode (vla-get-User preferences) acRepeatLastCommand)
    (alert (strcat "The SCMDefaultMode preference has been set to: " (itoa (vla-get-SCMDefaultMode (vla-get-User preferences)))))
    (vla-put-SCMDefaultMode (vla-get-User preferences) originalValue)
    (alert (strcat "The SCMDefaultMode preference was reset back to: " (itoa originalValue)))
GMT+8, 2026-10-27 00:37
