ScaleLineweights 属性 (ActiveX)
2024-5-18 16:55| 发布者: admin| 查看: 801| 评论: 0|原作者: admin|来自: AutoCAD
指定打印布局时是否将线宽与几何图形的其余部分一起缩放。
object.ScaleLineweights
类型:布局、PlotConfiguration
此属性应用于的对象。
只读:不
类型:布尔
  • True:刻度线宽。
  • False:不缩放线宽。
默认情况下,线宽以绝对大小(不缩放)打印。
为模型空间布局禁用该属性。
Sub Example_ScaleLineweights()
    ' This example reads and modifies the ScaleLineweights
    ' Layout value.
    ' When finished, this example resets the  value back to
    ' its original value.
    Dim ACADLayout As ACADLayout
    Dim originalValue As Boolean
    ' Get the layout object
    Set ACADLayout = ThisDrawing.ActiveLayout
    originalValue = ACADLayout.ScaleLineweights
    MsgBox "The ScaleLineweights value is set to: " & originalValue
    ' Modify the ScaleLineweights preference by toggling the value
    ACADLayout.ScaleLineweights = Not ACADLayout.ScaleLineweights
    MsgBox "The ScaleLineweights preference has been set to: " & ACADLayout.ScaleLineweights
    ACADLayout.ScaleLineweights = originalValue
    MsgBox "The ScaleLineweights preference was reset back to: " & originalValue
(defun c:Example_ScaleLineweights()
    ;; This example reads and modifies the ScaleLineweights
    ;; Layout value.
    ;; When finished, this example resets the  value back to
    ;; its original value.
    ;; Get the layout object
    (setq ACADLayout (vla-get-ActiveLayout doc))
    (setq originalValue (vla-get-ScaleLineweights ACADLayout))
    (alert (strcat "The ScaleLineweights value is set to: " (if (= originalValue :vlax-true) "True" "False")))
    ;; Modify the ScaleLineweights preference by toggling the value
    (vla-put-ScaleLineweights ACADLayout (if (= originalValue :vlax-true) :vlax-false :vlax-true))
    (alert (strcat "The ScaleLineweights preference has been set to: " (if (= (vla-get-ScaleLineweights ACADLayout) :vlax-true) "True" "False")))
    (vla-put-ScaleLineweights ACADLayout originalValue)
    (alert (strcat "The ScaleLineweights preference was reset back to: " (if (= originalValue :vlax-true) "True" "False")))
GMT+8, 2026-10-27 11:30
