ScaleFactor 属性 (ActiveX)
指定对象的比例因子。 支持的平台:仅限 Windows 签名VBA: object.ScaleFactor 属性值只读:不 类型:双人房 (ACAD_NOUNITS) 大于 0.0 的实数。大于 1 的比例因子将放大对象。介于 0 和 1 之间的比例因子可缩小对象。 言论此属性的初始值为 1.0000。 比例因子通常称为相对 X 比例因子。比例因子应用于对象的宽度,以允许独立于高度调整宽度。例如,如果比例因子值为 0.8,则绘制对象的宽度将是其正常未调整宽度的 80%。 Dimension、leader 和 tolerance 对象:此属性将覆盖 DIMSCALE 系统变量。 如果在图纸空间中工作,则尺寸的比例因子将等于 0.0,AutoCAD 将根据当前模型空间视口和图纸空间之间的比例计算合理的默认值。您将无法更改图纸空间中维度的比例因子。 例子VBA: Sub Example_ScaleFactor()
' This example creates a text object in model space.
' It then finds the current scale factor and changes it.
Dim textObj As AcadText
Dim textString As String
Dim height As Double
' Define the text object
textString = "Hello, World."
insertionPoint(0) = 2: insertionPoint(1) = 2: insertionPoint(2) = 0
height = 0.5
' Create the text object in model space
Set textObj = ThisDrawing.ModelSpace.AddText(textString, insertionPoint, height)
ZoomAll
' Find the current scale factor for the text object
Dim currScaleFactor As Double
currScaleFactor = textObj.scalefactor
MsgBox "The scale factor of the text is " & textObj.scalefactor, , "ScaleFactor Example"
' Change the scale factor for the text object
textObj.scalefactor = currScaleFactor + 1
ThisDrawing.Regen True
MsgBox "The scale factor of the text is now " & textObj.scalefactor, , "ScaleFactor Example"
可视化 LISP: (vl-load-com)
(defun c:Example_ScaleFactor()
;; This example creates a text object in model space.
;; It then finds the current scale factor and changes it.
;; Define the text object
(setq textString "Hello, World."
insertionPoint (vlax-3d-point 2 2 0)
height 0.5)
;; Create the text object in model space
(setq textObj (vla-AddText modelSpace textString insertionPoint height))
(vla-ZoomAll acadObj)
;; Find the current scale factor for the text object
(setq currScaleFactor (vla-get-Scalefactor textObj))
(alert (strcat "The scale factor of the text is " (rtos currScaleFactor 2)))
;; Change the scale factor for the text object
(vla-put-Scalefactor textObj (1+ currScaleFactor))
(vla-Regen doc :vlax-true)
(alert (strcat "The scale factor of the text is now " (rtos (vla-get-Scalefactor textObj) 2)))
GMT+8, 2026-10-28 02:20
