SavePreviewThumbnail 属性 (ActiveX)
2024-5-18 16:55| 发布者: admin| 查看: 882| 评论: 0|原作者: admin|来自: AutoCAD
指定是否将 BMP 预览图像与图形一起保存。
object.SavePreviewThumbnail
类型:PreferencesOpenSave
此属性应用于的对象。
只读:不
类型:布尔
  • True:不创建预览图像。
  • False:创建预览图像。
此属性的初始值为 。True
注意:此属性的值保存在 THUMBSAVE 系统变量中。
Sub Example_SavePreviewThumbnail()
    ' SavePreviewThumbnail. It then changes the value, and finally
    Dim currSavePreviewThumbnail As Boolean
    Set preferences = ThisDrawing.Application.preferences
    ' Retrieve the current SavePreviewThumbnail value
    currSavePreviewThumbnail = preferences.OpenSave.SavePreviewThumbnail
    MsgBox "The current value for SavePreviewThumbnail is " & preferences.OpenSave.SavePreviewThumbnail, vbInformation, "SavePreviewThumbnail Example"
    ' Change the value for SavePreviewThumbnail
    preferences.OpenSave.SavePreviewThumbnail = Not (currSavePreviewThumbnail)
    MsgBox "The new value for SavePreviewThumbnail is " & preferences.OpenSave.SavePreviewThumbnail, vbInformation, "SavePreviewThumbnail Example"
    ' Reset SavePreviewThumbnail to its original value
    preferences.OpenSave.SavePreviewThumbnail = currSavePreviewThumbnail
    MsgBox "The SavePreviewThumbnail value is reset to " & currSavePreviewThumbnail, vbInformation, "SavePreviewThumbnail Example"
(defun c:Example_SavePreviewThumbnail()
    ;; SavePreviewThumbnail. It then changes the value, and finally
    ;; Retrieve the current SavePreviewThumbnail value
    (setq currSavePreviewThumbnail (vla-get-SavePreviewThumbnail (vla-get-OpenSave preferences)))
    (alert (strcat "The current value for SavePreviewThumbnail is " (if (= currSavePreviewThumbnail :vlax-true) "True" "False")))
    ;; Change the value for SavePreviewThumbnail
    (vla-put-SavePreviewThumbnail (vla-get-OpenSave preferences) (if (= currSavePreviewThumbnail :vlax-true) :vlax-false :vlax-true))
    (setq newValue (vla-get-SavePreviewThumbnail (vla-get-OpenSave preferences)))
    (alert (strcat "The new value for SavePreviewThumbnail is " (if (= newValue :vlax-true) "True" "False")))
    ;; Reset SavePreviewThumbnail to its original value
    (vla-put-SavePreviewThumbnail (vla-get-OpenSave preferences) currSavePreviewThumbnail)
    (alert (strcat "The SavePreviewThumbnail value is reset to " (if (= currSavePreviewThumbnail :vlax-true) "True" "False")))
GMT+8, 2026-10-27 11:32
