SaveAsType 属性 (ActiveX)
2024-5-18 16:55| 发布者: admin| 查看: 957| 评论: 0|原作者: admin|来自: AutoCAD
指定用于保存图形的图形类型。
object.SaveAsType
类型:PreferencesOpenSave
此属性应用于的对象。
只读:不
类型:枚举acSaveAsType
  • acR12_dxf:AutoCAD R12 DXF (*.dxf)
  • acR14_dwg:AutoCAD R14 DWG (*.dwg)
  • ac2000_dwg:AutoCAD 2000 DWG(*.dwg)
  • ac2000_dxf:AutoCAD 2000 DXF (*.dxf)
  • ac2000_Template:AutoCAD 2000 图形模板文件 (*.dwt)
  • ac2004_dwg:AutoCAD 2004 DWG(*.dwg)
  • ac2004_dxf:AutoCAD 2004 DXF (*.dxf)
  • ac2004_Template:AutoCAD 2004 图形模板文件 (*.dwt)
  • ac2007_dwg:AutoCAD 2007 DWG(*.dwg)
  • ac2007_dxf:AutoCAD 2007 DXF (*.dxf)
  • ac2007_Template:AutoCAD 2007 图形模板文件 (*.dwt)
  • ac2010_dwg:AutoCAD 2010 DWG(*.dwg)
  • ac2010_dxf:AutoCAD 2010 DXF (*.dxf)
  • ac2010_Template:AutoCAD 2010 图形模板文件 (*.dwt)
  • ac2013_dwg:AutoCAD 2013 DWG(*.dwg)
  • ac2013_dxf:AutoCAD 2013 DXF (*.dxf)
  • ac2013_Template:AutoCAD 2013 图形模板文件 (*.dwt)
  • acNative:当前图形发布格式的同义词。如果希望应用程序以运行该应用程序的任何版本的AutoCAD格式保存图形,请使用该格式。acNative
  • acUnknown:只读。图形类型未知或无效。
此属性的初始值为 。以下值已过时:ac2013_dwg
  • acR13_DWG
  • acR13_DXF
  • acR14_DXF
Sub Example_SaveAsType()
    ' This example reads and modifies the preference value that controls
    ' the drawing type to save the drawing as.
    ' When finished, this example resets the preference value back to
    ' its original value.
    Dim ACADPref As AcadPreferencesOpenSave
    Dim originalValue As Variant, DisplayValue As String
    ' Get the OpenSave preferences object
    Set ACADPref = ThisDrawing.Application.Preferences.OpenSave
    ' Store current setting
    originalValue = ACADPref.SaveAsType
    GoSub GETVALUE
    MsgBox "The SaveAsType preference is: " & DisplayValue
    ' Modify the SaveAsType preference by changing it to AutoCAD 2000 DWG
    ACADPref.SaveAsType = ac2000_dwg
    GoSub GETVALUE
    MsgBox "The SaveAsType preference has been set to: " & DisplayValue
    ' Comment out this last section to leave the change to
    '         the preference in effect
    ACADPref.SaveAsType = originalValue
    GoSub GETVALUE
    MsgBox "The SaveAsType preference was reset back to: " & DisplayValue
    Exit Sub
GETVALUE:
    ' Convert the value of this setting to a meaningful text string
    DisplayValue = ACADPref.SaveAsType
    Select Case DisplayValue
        Case ac2000_dwg:  DisplayValue = "AutoCAD 2000 DWG (*.dwg)"
        Case acR15_dwg:  DisplayValue = "AutoCAD 2000 DWG (*.dwg)"
        Case ac2000_dxf:  DisplayValue = "AutoCAD 2000 DXF (*.dxf)"
        Case acR15_dxf:  DisplayValue = "AutoCAD 2000 DXF (*.dxf)"
        Case ac2000_Template: DisplayValue = "AutoCAD 2000 Drawing Template File (*.dwt)"
        Case ac2004_dwg:  DisplayValue = "AutoCAD 2004 DWG (*.dwg)"
        Case acR18_dwg:  DisplayValue = "AutoCAD 2004 DWG (*.dwg)"
        Case ac2004_dxf:  DisplayValue = "AutoCAD 2004 DXF (*.dxf)"
        Case acR18_dxf:  DisplayValue = "AutoCAD 2004 DXF (*.dxf)"
        Case ac2004_Template: DisplayValue = "AutoCAD 2004 Drawing Template File (*.dwt)"
        Case ac2007_dwg:  DisplayValue = "AutoCAD 2007 DWG (*.dwg)"
        Case ac2007_dxf:  DisplayValue = "AutoCAD 2007 DXF (*.dxf)"
        Case ac2007_Template: DisplayValue = "AutoCAD 2007 Drawing Template File (*.dwt)"
        Case ac2010_dwg:  DisplayValue = "AutoCAD 2010 DWG (*.dwg)"
        Case ac2010_dxf:  DisplayValue = "AutoCAD 2010 DXF (*.dxf)"
        Case ac2010_Template: DisplayValue = "AutoCAD 2010 Drawing Template File (*.dwt)"
        Case ac2013_dwg:  DisplayValue = "AutoCAD 2013 DWG (*.dwg)"
        Case ac2013_dxf:  DisplayValue = "AutoCAD 2013 DXF (*.dxf)"
        Case ac2013_Template: DisplayValue = "AutoCAD 2013 Drawing Template File (*.dwt)"
        Case acR12_dxf:  DisplayValue = "AutoCAD R12 DXF (*.dxf)"
        Case acR13_dwg:  DisplayValue = "AutoCAD R13 DWG (*.dwg)"
        Case acR13_dxf:  DisplayValue = "AutoCAD R13 DXF (*.dxf)"
        Case acR14_dwg:  DisplayValue = "AutoCAD R14 DWG (*.dwg)"
        Case acR14_dxf:  DisplayValue = "AutoCAD R14 DXF (*.dxf)"
        Case acNative:   DisplayValue = "Latest drawing release"
        Case acUnknown:  DisplayValue = "The drawing type is unknown"
    End Select
    Return
(defun c:Example_SaveAsType()
    ;; This example reads and modifies the preference value that controls
    ;; the drawing type to save the drawing as.
    ;; When finished, this example resets the preference value back to
    ;; its original value.
    ;; Store current setting
    (setq originalValue (vla-get-SaveAsType (vla-get-OpenSave preferences)))
    (setq DisplayValue (SaveAsTypeMsg (vla-get-SaveAsType (vla-get-OpenSave preferences))))
    (alert (strcat "The SaveAsType preference is: " DisplayValue))
    ;; Modify the SaveAsType preference by changing it to AutoCAD 2000 DWG
    (vla-put-SaveAsType (vla-get-OpenSave preferences) ac2000_dwg)
    (alert (strcat "The SaveAsType preference has been set to: " DisplayValue))
    ;; Comment out this last section to leave the change to
    ;;         the preference in effect
    (vla-put-SaveAsType (vla-get-OpenSave preferences) originalValue)
    (alert (strcat "The SaveAsType preference was reset back to: " DisplayValue))
(defun SaveAsTypeMsg (DisplayValue / )
    ;; Convert the value of this setting to a meaningful text string
    (cond
        ((or (= DisplayValue ac2000_dwg)
             (= DisplayValue acR15_dwg)) (setq DisplayValue "AutoCAD 2000 DWG (*.dwg)"))
        ((or (= DisplayValue ac2000_dxf)
             (= DisplayValue acR15_dxf)) (setq DisplayValue "AutoCAD 2000 DXF (*.dxf)"))
        ((= DisplayValue ac2000_Template) (setq DisplayValue "AutoCAD 2000 Drawing Template File (*.dwt)"))
        ((or (= DisplayValue ac2004_dwg)
             (= DisplayValue acR18_dwg)) (setq DisplayValue "AutoCAD 2004 DWG (*.dwg)"))
        ((or (= DisplayValue ac2004_dxf)
             (= DisplayValue acR18_dxf)) (setq DisplayValue "AutoCAD 2004 DXF (*.dxf)"))
        ((= DisplayValue ac2004_Template) (setq DisplayValue "AutoCAD 2004 Drawing Template File (*.dwt)"))
        ((= DisplayValue ac2007_dwg) (setq DisplayValue "AutoCAD 2007 DWG (*.dwg)"))
        ((= DisplayValue ac2007_dxf) (setq DisplayValue "AutoCAD 2007 DXF (*.dxf)"))
        ((= DisplayValue ac2007_Template) (setq DisplayValue "AutoCAD 2007 Drawing Template File (*.dwt)"))
        ((= DisplayValue ac2010_dwg) (setq DisplayValue "AutoCAD 2010 DWG (*.dwg)"))
        ((= DisplayValue ac2010_dxf) (setq DisplayValue "AutoCAD 2010 DXF (*.dxf)"))
        ((= DisplayValue ac2010_Template) (setq DisplayValue "AutoCAD 2010 Drawing Template File (*.dwt)"))
        ((= DisplayValue ac2013_dwg) (setq DisplayValue "AutoCAD 2013 DWG (*.dwg)"))
        ((= DisplayValue ac2013_dxf) (setq DisplayValue "AutoCAD 2013 DXF (*.dxf)"))
        ((= DisplayValue ac2013_Template) (setq DisplayValue "AutoCAD 2013 Drawing Template File (*.dwt)"))
        ((= DisplayValue acR12_dxf) (setq DisplayValue "AutoCAD R12 DXF (*.dxf)"))
        ((= DisplayValue acR13_dwg) (setq DisplayValue "AutoCAD R13 DWG (*.dwg)"))
        ((= DisplayValue acR13_dxf) (setq DisplayValue "AutoCAD R13 DXF (*.dxf)"))
        ((= DisplayValue acR14_dwg) (setq DisplayValue "AutoCAD R14 DWG (*.dwg)"))
        ((= DisplayValue acR14_dxf) (setq DisplayValue "AutoCAD R14 DXF (*.dxf)"))
        ((= DisplayValue acNative) (setq DisplayValue "Latest drawing release"))
        ((= DisplayValue acUnknown) (setq DisplayValue "The drawing type is unknown"))
  DisplayValue
GMT+8, 2026-10-27 11:07
